The 'ol single spinner ain't gonna be fun much longer as I start to add a bit of power. I haven't hit the track in the 335 but I did a few in the 330 and even with a lot less power the need for an LSD was there.
I'm throwing around some options, all of which are out of my price range atm (a fair few maintenance items to do first). Quaife is up there but there is a mob in the states that have a helical LSD shipped to me for around $1300 USD which seems reasonable.
A few guys are going 8.8" ford but I don't want to have to deal with modified housings or shafts or anything. Makes life difficult in the future.
Ultimately I'd love a BMW LSD that would just be a straight swap but they rarely come up.
Do I need to get these installed with some kind of specialist diff mob? Its definitely not something I'd try on my own.
Thanks guys.
https://www.sau.com.au/forums/topic/484806-my-car-needs-an-lsd/
There's a guy in NSW that specializes in BMW Diffs, 'Kurtis Aroney' supposedly.
There's also Difflab, who are in QLD and seem to know their modern BMW Diffs. Maybe someone in the local timezone that you can speak to :D
  • Like 1
You can install a complete diff by yourself - you'll need a 50mm open end spanner to undo (and redo) the nut holding the driveshaft to the diff. Some of the underfloor insulation needs to come out to get access, but I've done it (on a 335i) on jackstands in my garage.
Oh, I meant more about the internals if I was going to put a quaife in or similar.
Thanks for this, I'll reach out and get some figures. I do think its going to be damn pricey though.
I was going to add a line about not trying to change internals but decided that was too obvious🙂 I wouldn't do it - the setup of a diff is a pretty specialist area.
Edited by GeeDog
  • Like 2
Yep cool, it definitely looks scary on Youtube :D
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
