Hi Guys!
I'm having problem with my climate control unit, it died all of a sudden. Checked the fuses and relays. The buttons light up with the headlights but nothing on the display nor any of the functions work, including the re-circulation and rear defrost.
I have noticed another post from a few years ago on the same topic but there was no solution mentioned.  Any other ideas?
Any help would really be appreciated! Thanks!!
Well, I checked all the fuses in the fuses box and they were all good. I swapped the A/C relay with a known good relay and the climate control unit was still dead.
I have not checked the back the climate control unit with a multimeter for power as I do not know which terminal/wire should have power when it’s supposed to.
Oh I never fit any parts.  I just order them and put them in various piles in the shed!  I've spent more money on parts on my car over the past 10 years than I bought my car for and the majority of those parts are not in contact with the car!
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
