I keep going back and forth on this and just wanting some opinions.I currently have a set of r34 (im pretty sure) sumitomos on my stagea rs4 daily/street hooning car that's mostly stock. They're nice and quiet with decent stopping power but I have felt them fade a bit doing some spirited driving coming down the mountain.
recently I found a full set of z33 brembos with stock pads, rotors, and lines for a really good deal and picked them up.
Is it worth swapping to the brembos or should I sell them and buy slotted rotors, better pads, steel lines and fresh seal kit for the sumitomos? Wanting to get around 450hp with some light track use in the future.
https://www.sau.com.au/forums/topic/484812-r34-sumitomo-vs-z33-brembo/
3 minutes ago, MBS206 said:
I would start with a complete bleed of the brake system too with fresh brake fluid.
Most fade people get on the street is either from pads not suited to the driving, or old fluid that isn't happy anymore.
The fade only happens going downhill on the togue after a few hairpins. But my pads probably have 2mm left in the front so no matter what I'll be swapping those and doing a fluid change
The Z33 Brembos use a 324mm disc as well, would be much better than the 310mm R34 GT-t Sumitomo setup.
I run the Z33 Brembos on my shit box and it seems to stop well at Sydney Motorsport Park's GP Circuit. I have only 437kW, so not huge power but can happily do 2x hot laps before experiencing any brake degradation. Currently using Intima RS pads (superseded model).
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
