Thank you.
The wiring is okay, i double checked it with a Multimeter. The Sky goes out only in right curves and only if the fuel tank isn't full (the issue starts at about a half-full tank)
In Germany more r32 have this issue. First i thought i need a tank-in-tank solution to counteract the G-Load.
I think that, as GTSBoy said, it will relate to how the oump is mounted in the  cradle. Less likely but also possible the cradle is not firmly secured to the mount in the bottom of the tank and has come loose.
Either way you need to open the tank back up to check.
The main thing to check is that the pump's sock/inlet filter is lying flat right at the bottom of the cradle. Also check the the filter is properly attached to the pump and can't leak, that the pump is secure in the cradle (as the diameter is much smaller than stock), and that the return line from the fuel rail is properly connected so that fuel returns into the cradle not the main tank.
I still have surge with low fuel (under 1/4 tank) in long high g corners on the track, even though I use an in tank lift pump + external surge tank. These days there are better designed aftermarket alternatives if you can't get the standard setup to work OK, like https://frenchysperformancegarage.com/collections/nissan-skyline-r32gt-r/products/fpg-new-nissan-skyline-r32-gt-r-bnr32-in-tank-surge-tank-kit-track-edition-te-fits-c34-stagea-v3-fpg-085
I think you missed the point of what I said. You would need to be driving around a right-hand curve at the same time as measuring with the multimeter to prove this.
What I said was:
10 hours ago, GTSBoy said:
or you've fouled up the wiring so that it is shorting or going open circuit under that G load.
with emphasis added, for, you know, emphasis.
Yeah, I'm betting a combination of fuel pump is positioned higher then the factory pump and the filter/sock is shorter then the factory sock.
Have a look at the frenchys performance garage hanger setup, they generally position the fuel pump nice and low so would be a good comparison for however you set your pump up.
  • 1 year later...
Hello again,
I just want to tell you that i found the reason why my bnr32 is going out in right corners.
I had my car tuned by a company and they fitted the Emu Classic and a new fuel pump in 2021.
I checked the loom, changed the walbro fuel pump with a Deatschwerks fuel pump. None of this helped.
Then I checked the fuel pressure and thought I was crazy. It was tuned with over 7 bar ( over 100psi) !!!
But why? So I checked the fuel return line and saw that it was closed.
That was probably also the reason why the tuner replaced the fuel pump, but he tuned the Emu with the 7 bar 🫣
The map in the emu has now been changed and evertyhing is fine.
Edited by Stivo
  • Like 5
On 10/26/2024 at 12:06 PM, Stivo said:
Hello again,
It's my experience that when cars get old enough every failure starts to be unique and surprising like this. They must be reading Anna Karenina or something.
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
