Having an odd issue with my 92 GTR, at least I think its an odd issue because I only have my other obd1 cars to compare it too. I'm trying to solve a misfire and rich condition on the car and currently looking at the o2 sensors. I have a consult 1 cable and the nisscan software to monitor everything.
Here's whats odd, the "O2 Sensor" (which I'm assuming is the front one, or left sensor) shows a very slight movement, around 3-5 on the dial's 0-100 scale. Not sure what the 0-100 is, guessing 0v-1.00v given they are narrow band sensors?
First issue is that I feel like thats way too low for the sensor to be reading if thats the case?
The next issue is the "O2 Sensor RH" (which I'm guessing is the rear o2 and right side one) is just pegged at 100 all the time with no movement at all.
Makes me think bad sensor.
To check I unplugged the back/right sensor under the hood and the gauges never changed. RH one still showed 100 and the left one kept floating around 3-6.
Then I unplug the left/front sensor and both gauges go to zero.
I don't think thats how it is supposed to work but I'm still new to the Nisscan software and how the data should be read.
Can someone help shed some light on what is going on and if how this is reading is normal or do I have a major issue here?
This is what it shows with the car running at idle.
Edited by atomicmecha
Obvs they should both, semi-independently, flick back and forth between about 0V and 1V, at least when the engine is running in closed loop mixture control.
It may not want to idle in closed loop, because at idle the sensors can be too cold to work properly. They become lazy and usually read very low. The ECU disregards them and just runs open loop.
They can also act like that if their internal heaters fail.
If they are old, it is a fair bet that either one or both heaters have failed or they are otherwise old and sick. they do not last forever.
It is also possible that the wiring is borked in some fashion.
Does it do that when you're cruising at say 60-70 kph? At idle it will bounce between 20 and 80 for some time before finally getting too cold to read and going down to roughly 0 and staying there even when the engine is fully warmed up. O2 will start sluggishly responding around 30C coolant temp when you're driving around as well.
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
