Having an odd issue with my 92 GTR, at least I think its an odd issue because I only have my other obd1 cars to compare it too. I'm trying to solve a misfire and rich condition on the car and currently looking at the o2 sensors. I have a consult 1 cable and the nisscan software to monitor everything.
Here's whats odd, the "O2 Sensor" (which I'm assuming is the front one, or left sensor) shows a very slight movement, around 3-5 on the dial's 0-100 scale. Not sure what the 0-100 is, guessing 0v-1.00v given they are narrow band sensors?
First issue is that I feel like thats way too low for the sensor to be reading if thats the case?
The next issue is the "O2 Sensor RH" (which I'm guessing is the rear o2 and right side one) is just pegged at 100 all the time with no movement at all.
Makes me think bad sensor.
To check I unplugged the back/right sensor under the hood and the gauges never changed. RH one still showed 100 and the left one kept floating around 3-6.
Then I unplug the left/front sensor and both gauges go to zero.
I don't think thats how it is supposed to work but I'm still new to the Nisscan software and how the data should be read.
Can someone help shed some light on what is going on and if how this is reading is normal or do I have a major issue here?
This is what it shows with the car running at idle.
Edited by atomicmecha
Obvs they should both, semi-independently, flick back and forth between about 0V and 1V, at least when the engine is running in closed loop mixture control.
It may not want to idle in closed loop, because at idle the sensors can be too cold to work properly. They become lazy and usually read very low. The ECU disregards them and just runs open loop.
They can also act like that if their internal heaters fail.
If they are old, it is a fair bet that either one or both heaters have failed or they are otherwise old and sick. they do not last forever.
It is also possible that the wiring is borked in some fashion.
Does it do that when you're cruising at say 60-70 kph? At idle it will bounce between 20 and 80 for some time before finally getting too cold to read and going down to roughly 0 and staying there even when the engine is fully warmed up. O2 will start sluggishly responding around 30C coolant temp when you're driving around as well.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
