1 hour ago, Dose Pipe Sutututu said:
Euro 4 or 5 or 6 spec?
I'm heading down the same path (soon), however might do a 3" AES valve to bypass the cat/mid muffler and join back to the rear muffler if post turbine pressure creeps up.
Similar to this:
https://www.facebook.com/project7dere/posts/pfbid02TRQxyu9g19CJc1wit6yddh9WyDhjo3uabivNzsG5r5DhjWkg2ZPfgtUuLG4rGMhVl
i.e. no Western Sydney GT-R mode
Euro 4, IIRC 2 of the 4" body ones for my 3" Y pipe
Only a couple of hundred each, the Euro 5 high flow were more expensive but had a 5" body, I needed 2 so cheaped out on the Euro 4
The car (2002) only needs to meet Euro 3 but it ain't stock, so 1 extra Euro was acquired, which going of todays conversion rate is $1.67AUD, so I'm making money not fumes!!!!!!!:35_thinking::4_joy:
  • Like 1
11 minutes ago, Murray_Calavera said:
If you get a chance to do before/after dyno runs when you throw the real cats in I would be super keen to see the results
Car will just go back on with the same timing map, fuel map & boost, same type of dyno, however not the same one and my old run won't be there either.
However being a Mainline Pro Hub, they seem to be quite consistent in terms of reading.
  • Like 1
2 hours ago, R3N3 said:
We have pretty loose emission laws here in NZ and I did not need a cat to keep my car legal…. However I may look to install one in the future as I’m hoping it will also remove a db or two from the volume of the exhaust.
It will reduce noise substantially. When I got my car CA emissions compliant they added a bunch of cats and despite the Apexi catback and HKS front pipe it's quieter than a 100% stock exhaust. It also causes a hilarious amount of exhaust restriction because of how many they added but at least for now that means my turbos on wastegate boost no longer hit the R&R corner of the map.
Edited by joshuaho96
  • Like 1
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
