hello First time poster on any sort of forum so please be nice!
looking on advice/experiences people have had with pulsar turbos more specifically the 3576 or 3076, I’m building a r31 with a rb25det series 2 and wanting 300kw, I’m looking for a turbo that won’t come on until low to mid 3k rpm and full boost before or around 4K, only mods that may affect response that I have are top Mount mani and a FFP, thanks in advance :)
Edited by Liam2421
https://www.sau.com.au/forums/topic/484845-psr-3576-vs-3076-rb25det/
58 minutes ago, robbo_rb180 said:
What fuel?
3076 with do 300kw easy and have good torque everywhere be on well around 3k. Friends went 350ish kW on e85 and aeroflow equivalent 3076 and big rear housing.
Ah yes Just pump 98
yes I’ve been leaning towards 3076 just trying to figure what size rear housing will get me the response I’m after, im thinking .82?
21 hours ago, Liam2421 said:
Ah yes Just pump 98
the dyno graph I posted some time back, i think it was in the Hypergear thread? Was for a Garrett GTX3076Rg2 with a 0.82 rear housing on 98. I don't have the dyno PDF on this PC to post again sorry, but search and you should find it. It was 'around' the 300rwkw (PITS dyno apparently reads a little lower than some). I ran it with a 0.68 housing and yeah a bit small, the top end of the 0.82 outweighed the slight increase in responsiveness. I will do a sales plug lol, I have it for sale if you're in Aus and want it...only done about 2000 k's, almost brand new. I also have the Hypergear turbo I compared it to which made a little more power as per my post, but that turbo's done more like 40,000 k's, still good though. No use for either now as I've switched to the G30-660.
I will say, while the Hypergear made a little more, the Garrett felt like the real power would come running a little more boost than 21 psi, like it was just starting to come alive. Sounds cooler than the Hypergear too I've gotta say 😁, more whistle than a steam kettle on the boil.
  • Like 1
I have a query, but why do you want to hold back the outright capability of the mechanical system?
Would it not be better to build a system that is responsive as possible, that meets your upper requirements, and then use electronic measures to control and manage it?
That way you're not left with a car that you might want a bit more response from but can't mechanically achieve it.
That's my frame of mind on all of this. Would mean you also have a more responsive and driveable car on the freeway etc without needing to drop gears.
Power on tap with mid throttle.
to also add, in my experience the Pulsar turbos are good, but were just a little short of the performance of a genuine Garrett...get what you pay for hey. I tried both a Pulsar G30-600 and then the Garrett G30-660, and that was my impression. Using the same 0.73 exhaust housing on both.
  • Like 1
Personally I like when boost slowly rolls on and having boost come on later between 3-4K seems like a more usable power for street driving/ cornering at speed the power will be there, just a personal preference more then anything :)
Thanks for your advice! Yea I’ve read on a few forums that these turbos make really good noises! But when trying to find out when they boost vague and conflicting answers, I am in aus nsw yes, I have alot of money to spend elsewhere first(Haltech,25det gbox conversion) but can’t hurt to ask how much just in case the price is right :)
indeed..for the gearbox, if you get a 2ndhand RB25det box in excellent condition then great, but if not, don't waste your money rebuilding it. I did, and for what it cost me, would have been better to buy a new R34 box. Although it was a good learning experience to rebuild it, it was just not cost-effective and some parts are unavailable now so couldn't 'fully' rebuild it as I'd like to have done, eg 2nd and 3rd gears.
For the turbo-sale-ness, would do the Garrett for $1200 plus 30 postage, the Hypergear prob, $1000? For your build I would suggest the Garrett; I say this because from your build and going Haltech I'd say in the not so distant future you're going to want ' more" and the Garrett will likely give you more, as well as being as good as brand new...up to you of course.
I recommend the @hypergear . I run the hypergear ATR43ss2 ball bearing) and I’m at 320kw with full boost at 4000rpm (on pump 98). I also run in low mount configuration with wastegate welded to exhaust housing, so no need for a new exhaust manifold. Check my build thread for details.
the noise of the turbo is also real nice. You can definitely hear that spool!
Edited by R3N3
  • Like 1
What are your thoughts/results with the 0.73 housing on the G30 660? I’m tossing up whether to get one of the GCG G30 770s for my RB25.
Yes everything has gotten a lot more expensive since I last had a skyline it’s nuts for example last time I bought a 25det it cost me 1500$, I just payed double that a few weeks back for one  and that seemed to be on the cheaper side 😳I already have a 25det gearbox just have to buy clutch, modify tailshaft and buy a new speed sender etc which is all adding up quick! That is a good price I’ll have a think on it thankyou!
At the expense of sounding like an idiot I apologise but how do I check out your build thread ? Sorry I’m still learning how to use sau 😂
Here's Rene's thread, very concise information.
Meanwhile here's mine, I run a Garrett GTX3576R Gen 2, on a 1.01 divided rear housing and make ok power. Just be a heads up, there's heaps of house renovation talk too (and some ok car info) lol... I suggest to start from like page 98 or so.
  • Like 3
to me it's the perfect size; the 0.63 or whatever it is, can't remember, is too small, so the .73 gives good spool but still enough top end flow. Couldn't say on a 770 though?.
0.73 can be a hard size to find though I think - the Pulsar G30-660 came with it, so I'm using it on the Garrett supercore.
  • Thanks 1
I've included some data from current model ATR43SS-2 turbo. Its very different to the 2019 version mentioned by Hardsteppa, and makes a lot more power. On this R33 Rb25det, it sit on 25psi by 4K and 372rwkws, that was on pump 98 fuel externally gated, They do around the 400rwkws on E85 fuel.
Turbo can sounds like a Jet, I've attached a short vid from a recent dyno tuning:
  • 11 months later...
.63?
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
