Hey RB Gurus,  My fresh built RB26 is making an interesting ticking noise from the head.  Valve Lashing has been checked and is supposedly perfect.  Sound is definitely coming from the head.  Take a listen and let me know what you think?
https://drive.google.com/file/d/1RkCSL0AL7IzFebLuIAd2cdDpkbxOTP-6/view?usp=drive_link
  • Like 1
https://www.sau.com.au/forums/topic/484870-rb-26-sound-input-help/
11 minutes ago, Dose Pipe Sutututu said:
Take off the cam covers and inspect the cams, sounds like either there's not enough oil going to the head or your head hasn't been shimmed correctly.
Shims have been verified.  And the cams seem to be good.  The head does have the restrictor in it, but the car has N1 oil pump w/ boundary gear.
  • Like 1
On 8/18/2023 at 10:29 PM, SLVRBAKSLPZ said:
Have you looked in the oil filler or taken a cover off with the car running? Try to assess the pil pressure and pinpoint the sound better.
I haven't, but thats not a bad idea.  I suspect the sound is coming from the intake cam side so that may very well help.  Its quite a bit of disassembly as I also have the hypertune Baffles.
  • Like 1
U figure anything out?
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
