1993 Model GTST Skyline Black, Has been well looked after.
I just lost my license for a year speeding in a rav 4 :P, and there comes a time when you just have to move on.
Car is pretty much Standard, not many mods done to it at all.
Car has done 95,000 km
car has had its 100k service
- 18 Inch DTM Wheels
- Pioneer CD Player
- Carbon Fibure Boost Gauge
- Brass Button Clutch
- 5 Speed Manual
- 3 Inch Cat Back Exhuast
- Hi flowed cat :D
- Boost Controller
- 400 R Front end, painted and can be fitted on request
18,000 ono
This car gets serviced every 5,000kms, i am the first owner to have it in Australia and have only put 10,000ks on it since i purchased it. I only drive this car on weekends as i have a rav 4 to drive to work in. what can i say "it keeps the police away".
if you are intrested, no need to keep posting in here, call me on 0401 847 645
or you can email me [email protected]
http://members.optushome.com.au/mary27/mybeast.jpg
if you want more photos, email me
thanks
https://www.sau.com.au/forums/topic/48489-nissan-r33-gtst-for-sale/
Yeah im interested could i get some more pics, would you be interested in smaller car plus some cash adjustment???
hi matey
I have place some photos on the internet so that you can all see, you can find them at the links below
http://members.optushome.com.au/mary27/pic1.jpg
http://members.optushome.com.au/mary27/pic2.jpg
http://members.optushome.com.au/mary27/pic3.jpg
This is currently what the car looks like at the moment, does not have the 400 R Front end on it atm can be put on, i found the 400R front end way too low, and gets scratched really easily.
Im happy to swap maybe a van, ute or something that i can use to transport stuff around in and keep away from the cops, what car did you want to swap?
Any questions feel free to call me, or email me i dont bite.
My car is a Holden Barina SXI 2003, RED, 5 speed, Aircon,power steer,power windows, Holden Alloys, balance of new car warranty, worth $14,000 plus some cash adjustment with that.
hey again
Nah not keen on a holden barina, i am really going to need something big to drive around in.
If you sell your car let me know, and we will talk about the price.
Hey mate nice car, in regards to the 400R front bar would that be fitted with the price staying the same or would the price increase? thanks.
The 400R Front end has now been sold, however I’m happy to re negotiate the price, if any one is still interested let me know. The car will be in next weeks trading post.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
