Hey guys,
Just wondering if anyone knows if there’s a difference between the turbo and N/A gearboxes for R34’s? From my current understanding the gt’s have a tcu, where the gtt’s box is controlled through the ecu, is there any actual difference in the box? Also because theres a tcu does that open up your auto aftermarket ecu options?
https://www.sau.com.au/forums/topic/484895-r34-na-vs-turbo-automatic-gearbox/
Yes the box is different. The auto shop that pulled both of them apart from me back in the day was surprised how different they were internally.
The pinout diagram for the TCU lines up with the pinout diagram for the GTT Ecu. It's not so much 'different' as much as it is integrated into the GTT ECU.
The only auto mod you make on a NA auto box is you take it out and leave it out. It will not stand up to any power, even if you build it.
Swapping to GTT gear is going to require extensive knowledge and study of the wiring diagrams. If you are paying someone to do this, it is not that feasible/cost effective.
There is a reason 100% of people go manual.
Don't want to go manual? Can't afford the conversion to go manual? Can't drive manual and don't want to learn? Sell the car.
This is the ballad of the NA Auto Skyline.
  • Like 1
Yeah man, i’m planning on manual swapping, just wanted to make sure that i was happy with the decision
Unless you're putting a wet clutch DCT or a ZF6HP or ZF8HP manual is the way to go. Automatics that don't have the lockup clutch running in all forward gears and modern shift logic are just really frustrating on something nominally meant to be high performance.
Nobody ever regrets it...
There's probably some merit to go off the deep end and end up with a BMW DCT or ZF8 as above, but it's not really a viable path forward unless you bought the car with this kind of knowledge in your head from previous car endeavors and had the skills, money, and patience to pull it off.
Given R34 N/A's are usually bought by young folks just buying their first performance car... this is statistically unlikely
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
