Hey guys,
Just wondering if anyone knows if there’s a difference between the turbo and N/A gearboxes for R34’s? From my current understanding the gt’s have a tcu, where the gtt’s box is controlled through the ecu, is there any actual difference in the box? Also because theres a tcu does that open up your auto aftermarket ecu options?
https://www.sau.com.au/forums/topic/484895-r34-na-vs-turbo-automatic-gearbox/
Yes the box is different. The auto shop that pulled both of them apart from me back in the day was surprised how different they were internally.
The pinout diagram for the TCU lines up with the pinout diagram for the GTT Ecu. It's not so much 'different' as much as it is integrated into the GTT ECU.
The only auto mod you make on a NA auto box is you take it out and leave it out. It will not stand up to any power, even if you build it.
Swapping to GTT gear is going to require extensive knowledge and study of the wiring diagrams. If you are paying someone to do this, it is not that feasible/cost effective.
There is a reason 100% of people go manual.
Don't want to go manual? Can't afford the conversion to go manual? Can't drive manual and don't want to learn? Sell the car.
This is the ballad of the NA Auto Skyline.
  • Like 1
Yeah man, i’m planning on manual swapping, just wanted to make sure that i was happy with the decision
Unless you're putting a wet clutch DCT or a ZF6HP or ZF8HP manual is the way to go. Automatics that don't have the lockup clutch running in all forward gears and modern shift logic are just really frustrating on something nominally meant to be high performance.
Nobody ever regrets it...
There's probably some merit to go off the deep end and end up with a BMW DCT or ZF8 as above, but it's not really a viable path forward unless you bought the car with this kind of knowledge in your head from previous car endeavors and had the skills, money, and patience to pull it off.
Given R34 N/A's are usually bought by young folks just buying their first performance car... this is statistically unlikely
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
