Link to Data-log Link G4+ ECU: https://1drv.ms/u/s!An_ML36HZBw-hhz3uvNXSiDLCIZp
Hi,
I am having hard boost or fuel cuts at around 6k RPM. First I thought it was due to overboosting (boost cut). But on checking the data log with my tuner we noticed that the trigger kit was having a malfunction during pulls. Boost or fuel is cut very hard. RPM gauge in the car really flips hard bounces back and forward. Red engine light pop-ups. In the data log you see the ECU measures engine speeds of 35k+. So the trigger/crank sensors are having some hard time for some reason.
I have a built engine and head with a full Ross trigger kit.
Hope someone can assist or has experience with this issue and what the possible cause(s) can be.
Edited by T.Krol
  • T.Krol changed the title to Ross Trigger Kit fault - data log LINK G4+ - hard boost/fuel cut 6kRPM
Check the air gap between the sensor and the wheel. I would put money on it being wrong.
A word of caution. Sort it out ASAP. This is no different to smashing the limiter… and we all know how much RB oil pumps love that.
  • Like 1
  On 30/08/2023 at 8:56 AM, T.Krol said:
Hi,
Thanks for the reply. You mean the air gap between the crank sensor and the wheel, just to be sure? I read that it should be 1 to max 2mm for both the crank as for the cam sensor.
Thanks.
Expand
Correct, the crank trigger sensor and crank trigger wheel.
Closest you can get without touching is best, so ideally under 1.5mm is recommended. I run a Ross trigger with hall effect GT101s. I have no shims on cam home at the standard set 1.4mm gap and the crank end is shimmed to be about 50 thou, which is about 1.25mm down here.
  On 01/09/2023 at 2:35 PM, T.Krol said:
Since the sensor is attached to the closed 'cap' over the cam gearing?
Expand
The sensor cannot be mounted onto the plastic cam cover. Not solid enough. Needs to be mounted on a solidly connected bracket. All of that can be put in place without the cover.
If it is like that, and it is under the cover, then the cover needs to come off to check.
If it connected to the cover, then it needs to change. Tout de suite.
Edited by GTSBoy
Threads at 2 of the 3 locations where you attach the cam trigger cap are not very good anymore. At least not with the bolts (believe m10) that were in there now. One bolt was already loose and when putting the cap back in, I couldn't get a 2nd bolt in. So now I'm stuck with 1 bolt. Can imagine that at high revs this could cause vibrations in the ross cap and thus the cam tooth giving a wrong signal to the sensor. Tomorrow just looking for slightly longer m10 bolts. Air gap of the crank looked very close and oke.
Hope this would fix the issue quit easily but I am not sure.
Well an update.
The air gaps looked very very close and perfect. Ran the car a bit. Still had the issue. Was about to turn around but decided to do one more 2nd to end 3rd pull. No trigger cuts. Look at the oil temp was around 72c. I have an oil cooler (no AC) behind the intercooler. So oil temps take long time to get up.
Did 10 more pulls 2nd to 4th, no cuts. Would it be possible the engine limit/speed is limited by certain oil temps below 70c?
Makes it even harder to put my finger on the issue. Problem seems to go away when the car is good on temperature.
  On 03/09/2023 at 7:44 PM, T.Krol said:
Well an update.
Expand
From what I saw, Adam had replied to your log suggesting you very much have a trigger issue. He will review the config file for you if you are nice to him.
The only time i had a trigger issue with link was when i have a poorly set pin on a deutsch plug.
Expand
If he can that would be awesome ofcourse. I really have no clue what causes it at this point. Id rather pin point it myself with the help of you guys before I drop it off at a shop and they have to spend hours searching..
  On 04/09/2023 at 4:09 AM, hattori hanzo said:
had this issue constantly with the ross binned it and went hi octane kit
Expand
I am using an ignite 5.0 and vcam combo on mine.
Expand
Post up your map  *never mind, just looked through your log, trigger errors for sure.
Edited by Butters
Expand
Yes trigger errors indeed. Non the less here is the map file. Perhaps someone can see something suspicious.
Thanks for the help so far.
R32 GTR T.Krol G4+ (trigger issue).pclrFetching info...
Edited by T.Krol
Typo
  • 4 weeks later...
Hi,
Well I have no idea what the cause might be. Whenever the oil is above 70c and intake temps are above 24-26c I have no trigger issues at all. But when the outside temp is low and intake temps are under 20c and engine oil doesnt come above 62-66c (external oil cooler) I have the trigger issues.
My tuner checked the map and there are no engine oil temp restrictions on power delivery/rpm targets.
Anybody any idea what else could cause this? Feel free to check the mapfile here above.
Thanks.
Edited by T.Krol
Expand
And Ross Performance will happily ghost you when things go south.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
