Hi all, I keep finding more and more things to change when doing a clutch change but my mechanic didn't tell me there were other things that could be changed so wanted to check if I got my list right (let me know if anything is missing):
Full clutch kit that comes with all the components
rear main seal (might as well while its out)
clutch fork
input shaft oil seal
Fly wheel remachined
front and rear input shaft bearing (worth changing?)
Yeah no pivot ball for the pull type. I went through the same process last year:
In the end I just ended up getting the spigot bush and clutch fork. The fork not really being needed as it's solid but thought what the heck and did it anyway. Flywheel came with the clutch. There's also the little rubber dust cover that goes on outside. Which in the end also came with the clutch.
I hope you are getting a good clutch. It makes all the difference for actually enjoying to drive the car :)
Yeah will be a basic exedy heavy duty clutch. Do you know if its worth replacing the input and output shaft bearing? I'm guessing they are behind the input shaft itself before the 4 bolts?
14 minutes ago, Duncan said:
I can't see spigot bush on your list, it is worth always changing that when you do the clutch
That will come in the clutch kit, that's actually the main thing + clutch, I need to change because I'm getting grinding noise at idle and when accelerating at certain speeds but goes away when the clutch is in.
Edited by silviaz
Do you know if input and out shaft bearing is behind the input shaft or it's deep in the gearbox? Wasn't able to find info on it.
Upgrade anything you need to remove, that could help performance.
Like the exhaust. While you're there, may as well do the turbo since it touches the exhaust too...
Get the tailshaft double checked too...
  • Like 2
48 minutes ago, Duncan said:
They are both in the gearbox.....box out if they need replacing
I know the gearbox needs to be removed, but was wondering if it's right behind the input shaft as the amount in labour will be alot cheaper to replace it, but will be alot more if it's buried all the way in the gearbox.
    • Chrome surrounds back on and polished up, no idea why some knob would prime a single piece 馃檮
    • Well, in the same way that you can't tell any SUV from any manufacturer in any size category from any other one, "sports" coupes now all look identical. Stand back and squint your eyes and the Supra and the 400Z and the GR/BRZ things all look the same. I was just thinking last night, when sitting behind a Subaru CrossTrek, that I have no idea what it is, how it differs from an XV, or a Forester, or an Outback, or anything else Subaru offer, and I couldn't tell if it was supposed to be small, medium or large. I contrasted that to the good old days, where a HQ Kingswood had familial similarities to an LJ Torana, but there is no way that you could confuse them, and how a bit later, the HX Kinger and the concurrent Torana and the Gemini all had familial similarities, but you still could not confuse them. Ditto the ugly Fords and Chryslers of the era. But now, a RAV4 looks like a Kluger, looks like a Yaris/Cross/whatever they're calling those stupid f**king things, looks like every other Toyota that's not a Camry/Corolla sedan.
    • The Prelude doesn't look that bad without all that lens distortion in those pics. Makes it look disproportionate when it isn't. Actually I kind of liked it at the Osaka Auto Messe earlier this year.
    • Pour in the highest octane, non-ethanol fuel you can get and see if the readout changes. If it's dead bang on 11% then I would question the sensor. Another quick test, just take it out and run normal (in an american accent) gas-o-line through it and see if the sampled ethanol or lack of changes.   United E85 here in the land of drop bears does vary a bit, I've had as high as E87 (could be water in their tanks too, who knows)
