Will back up what trident said.
Pull it again, and check the marks. Take photos of all the marks and post them.
Also check the harmonic hasnt spun the outter section which has the timing marks.
Also check you've reconnected everything properly, all pipes, cables etc.
Do you have adjustable cam gears, or factory ones?
When you say it won't rev, does it start all perfectly normal, but then you try and press the accelerator and it won't rev up?
Or you're having to start the motor with throttle, especially a lot of it?
If the latter, I suspect you have one cam advanced massively, another retarded massively, and you've done this by lining the gears up on the wrong mark. Been there, done it myself on an RB25DE head.
Car would start and run a bit, but was basically at WOT only it would run (and wasn't much over idle RPM). I also had an aftermarket ECU, so was running MAP not AFM.
yeah as far as i know all 3 of the marks are lined up (i’ve checked about 4 times because of this issue) i will take it apart tomorrow and post it on here
when turning the car on from cold i have to use throttle but idles fine. when revving when driving it almost spatters and won’t go much higher then 3000rpm
i have factory cam gears
the harmonic balancer has definitely not spun
Have you actually verified TDC cylinder 1 is where the balancer says it is? Has this engine been rebuilt at all?
Double check the AFM is plugged in too, AND both temp sensors are plugged in too.
Do a huge double check for air leaks too.
27 minutes ago, Cozzamb said:
not sure how i would verify TDC for cylinder 1 as i’ve just been doing everything off the workshop manual
Spark plug out. stick/screwdriver in the hole. When it stops going up and starts going down, that's TDC. Very hard to catch the exact top because the motion slows down as it dwells across the top, so you end up needing to look at the height of the indicator a few degrees either side of where you think TDC is. If it is at a certain height and rising at some indicated angle and then it is at the same height and falling at some other later angle, then halfway between those angles is true TDC.
12 hours ago, blind_elk said:
Sometimes, the timing light indicates the incorrect timing. How did you actually measure / set timing?
This is worth thinking about, personally I hate worrying about whether the inductive loop or whatever is all set up correctly. I just use a spark plug wire on cylinder 1 instead.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
