Hey all so will give you a quick rundown so I have an rb20det, she starts occasionally idles for a few minutes then shuts off and refuses to start again, now I have go one wires, piping, put new cas sensor, new afm, new sparks, new fuelpump, new ecu, 02 sensor, i pulled the fuel filter off and bypassed it still nothing, puthave tried resetting the ecu, have no bloody luck with it at all, will attach a video on it hopefully it help you rb gurus, any info would be appreciated just trying to get the girl running, cheers heaps team, much appreciated
Video is not working here either. Just the sound.
From PM
"Have you got your fuel lines hooked up the right way around? The in and the out are both at the front there, and there is an FPR on the outlet end and there is a pulsation damper at the inlet end. The inlet goes into the front end of the rail and the outlet comes out of the back end and then runs back up to the front. If you hook it up backwards, it won't work. "
It doesn't sound like fuel pressure slowly bleeding off. If you pull fuel pump there will be a moment where it runs rough as it leans out. I could be wrong but it sounds like it just shuts off as if someone turned the key off. My first instinct is pull ECU logs and see what's going on the moment it dies.
Yeah most definitely just shuts off exactly like that, yeah I'd most definitely do that but don't have a consult adapter....
    • I hope one day I can do it like you. Your engine looks great.
    • If there's nothing else I can do I'll probably do something like that Someone on the internet said that ca20s and ca18 engine blocks are the same and that you can use a ca20 engine block and put ca18det parts to make a ca20det Do you think this is possible or will it damage the engine?
    • Yeah, I did some research and found out that some things are different.
    • Makes sense, thanks! Consider me very impressed. And I very much appreciate the effort in documentating all of it. You'd be surprised, or maybe not, how many people this reaches who search for things online. Anyways, I shall continue to read all of it, understand maybe a quarter, and hope that some of it sticks if I ever end up in a situation where it's relevant
    • 'Did' work on them is more accurate ~ on the R31 Skyline forum, you can spot me as 'Solder'... I've written quite a bit about the 4R01 boxes there, and I ended up reverse-engineering the older TCU type operations, so we could fudge a custom TCU to pull off other tricks...and like all things, when you do it a lot, see the failure patterns, have to find parts etc etc, your head ends up filled with whys and wherefores... there was a reason Nissan went with these in more than 60models over 16+ years... all in all, the JR401E based design is an interesting study, as Nissan changed things over the years in a never ending battle against them lunching on themselves <grin>...by the time the RE4R01A rev.C came out (often referred to as RE4R01B), they'd more or less perfected the design...
