Hey guys, Ive been a silent reader for years and love this community. I am wondering if you guys have recommendations for a pop-up screen entertainment unit that comes with a rear view camera ? preferably plug and play cos i kinda suck at wiring and etc. for the GTR r33.
I love my 3 gauges hence the pop-up idea. or alternatively, you guys know where i could find a replacement trim for the 12v outlet + ashtray to fit the climate control console (i know yoshida makes one but they sell them for a price i could not afford). That way I could just use a screen unit that takes "two console" spaces.
In short, I want a screen, rear view camera, and to keep my 3 gauages and climate control.
Thanks a million guys.
https://www.sau.com.au/forums/topic/484954-gtr-r33-pop-up-screen-choices/
Sounds like you're asking for a Pioneer AVH-3500NEX.
  • Like 1
One thing to consider with that, since the early 00s I had something similar in the stagea.
While it was single DIN, when the screen is open (all the time while driving), it blocked the climate controls and partly blocked the air vents (or in 33 GTR the triple gauges) anyway
Yeah there's no winning to some extent with the double DIN issue. Annoying either way. Personally I haven't used the stereo at all. If I ever get around to it I will replace it with a mechless single DIN with bluetooth and call it a day.
The other question was how to install without cutting wires. That's pretty simple. You can buy harness adapters for radios for 100% plug and play reversible installation. I don't recall what year of Maxima you're looking for in the US but that is how you do it.
I'd be interested to hear about some solutions for this as well. Similar situation as I'd like to keep the triple analog gauges.
That's a good point. Looks like on the Pioneer the default can be changed on whether it is open or not. And it has the usual radio control buttons even when it is folded.
Sounds a bit annoying regardless. I think it's possible to half move the screen, but looks like it's via touch screen controls only so not great whilst driving. There are some videos about the controls on youtube. Doesn't look like it's possible to move it by hand to just quickly reach the controls that are hidden when it's up.
Personally at $1300 AUD I'd want something that is pretty much perfect so not sure about this one.
Hah, I hear you. The speakers in mine are stuffed so haven't listened to music in the car at all. Weird how after a while it just becomes normal. Even considered blanking out the stereo slot out to make it look a bit cleaner.
Would be nice though to have a proper display with carplay/android auto integration.
The best way is the new Garage Yoshida injection molded HVAC relocation. He 3D-scanned an OEM shift surround piece and then modified the design in CAD to fit the HVAC unit. Should all just clip in and the look/feel of it should be just like stock: https://blog.garage-yoshida.net/archives/15611
Then any good 2-DIN unit will work.
  • Like 2
I hear you. But the trim costs an arm !
Thanks a lot pal, that’s what I’m looking for I think.
I see where you are coming from and I agree with you. I’m hoping to move the climate control to the bottom shelf, popup screen in the middle, and I’ll just live with the screen open knowing I have the 3 gauges behind it to feel good.
See, that is awesome, good on them for doing the R&D for something R33 owners have needed for years! Yes, not cheap, but for a smart solution to a real inconvenience I think it is reasonable.
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
