Hi guys. Need some suggestion, new to turbo car.
Got a r34 gtt automatic, all it got now it's a Nismo exhaust, is it possible to get around 200 rwkw out of an auto?
If so, which FMIC ( prefer straight bolt on kit), saw on Greenline website that HKS kit is not suitable for auto? fuel/air management, EBC and would a hi flow or new turbo required at the desired power output?
I guess I would like to have a overall package that will produce good response with big more power than stock.
https://www.sau.com.au/forums/topic/48496-help-what-mod-for-200-rwkw/
Your only option for engine management is the GReddy E-manage....luckily only just this weekend I've managed to find a way for the ignition harness to be wired in without issue!!!
Check out the e-manage Thread at the top of this section to get more info on it...it's the last few pages that are relevant.
I think you could move the trannie fluid cooler to the drivers side inner guard, like the opposite of the standard intercooler then you would have no issues with any fmic that is made for a GTT. Also you may be able to modify the mounting bracket to move the fluid cooler closer to the radiator.
Emanage should be the way to go although I am still experimenting with a modified standard ECU. I currently have 189 rwkw with stock cooler, stock turbo, panel filter, 0.8 bar boost and a good exhaust.
I have heard of a few people getting no extra power from a fmic with R34's unlike R33's and R32's which seem to pick up a bit automatically.
FYI, my GTT has been running EManage (minus ignition harness) for close to 2 years now and i am very happy with the result and response...no auto issues to date with crisp, fast changes but am considering auto mods such as altering stall etc. Current set-up: Hybrid FMIC, Hi-flowed standard turbo,Emanage,AVC-R (running 1 BAR), K&N Panel filter, Z32 AFM, 3" Dump, 3.5" JASMA exhaust and 3" CAT back, current power 220rwkW...am fitting Walbro internal 255lph fuel pump and searching for a set of injectors....
Cheers,
Michael
Thats weird Neo R34, I had the emanage setup with the Z32 but it wouldnt idle right.
Anyways here are some figure for u to think about:
At that time I had a front/cat back/e-01 boost controller and hks panel and i got about 170rwkw at about .85 bar.
Now I got the PFC/front mount/front and cat back/hks panel filter/ e-01 and I still only got about 180rwkw at about .7 bar.
I just cant seem to get power, anyways back to the topic. I agree best bang for buck is the Emanage. Neo mind me asking where u take ur car too?
ok. so greddy emanage seem to be a good option. I will look into that. thanx guys.
but what about stock R34 turbo n IC? Can they stand the daily grind of 200 rwkw or adding a FMIC and a hi flow/ new turbo(HKS 2530) are a more reliable option?
hoo@h- i think your questions are already answered in the above posts...look at the figures and mods, all will be revealed.
GroundRun- I am in Perth WA, if you are serious PM me and i will provide details. Check out for your own info the articles in back issues of HPI re: mods to GTT with manual and power gains...maybe your answers are there. Hope that helps.
Cheers,
Michael
Cheers,
Michael
Thanks Neo, looks like I can just follow your step and get that power figure i am looking for.
And, yes, I have got that HPI mag with the power figure n what mods are required, but just need to be sure that same mod apply to auto.
I guess I just want to know any other fellow auto r34 owner have achieved the result (200 rwkw) with a proven n reliable package. then I can just cut n paste it into me car. :P
by the way, I am in brissy, so if any1 know any good shop here that can do the sort of mod, please let me know. ta.
What's wrong with S-AFC? It may not have as many features, but it's still an option.
Nothing wrong with an SAFC...just thought the way he was talking he'd want some finer control of the ratios...and if he wanted to adjust ignition curves one of the only engine magement systems that'll work with the tiptronic is an e-manage.
Didn't want to tread on any SAFC toes :P
A full kit would be in your hands for $700 (e-manage + both harnesses + software) at the moment, and you can install it in less than a day easy
It handles boost cut and atmospheric BOV idle too...it really does have some good features.
You need access to a laptop...seriously though I used to have PC in the garage with a long cable on it that reached into the car....as long as you've got a computer nearby you can adjust the settings.
The benefit is it takes literally seconds to type in the new settings whereas PFC contollers are time consuming :(
Have a good read about it at www.mohdparts.com If you're considering getting one, get it from this guy (Mohammed) as his service is second to none..very helpful.
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
