Hi guys. Need some suggestion, new to turbo car.
Got a r34 gtt automatic, all it got now it's a Nismo exhaust, is it possible to get around 200 rwkw out of an auto?
If so, which FMIC ( prefer straight bolt on kit), saw on Greenline website that HKS kit is not suitable for auto? fuel/air management, EBC and would a hi flow or new turbo required at the desired power output?
I guess I would like to have a overall package that will produce good response with big more power than stock.
https://www.sau.com.au/forums/topic/48496-help-what-mod-for-200-rwkw/
Your only option for engine management is the GReddy E-manage....luckily only just this weekend I've managed to find a way for the ignition harness to be wired in without issue!!!
Check out the e-manage Thread at the top of this section to get more info on it...it's the last few pages that are relevant.
I think you could move the trannie fluid cooler to the drivers side inner guard, like the opposite of the standard intercooler then you would have no issues with any fmic that is made for a GTT. Also you may be able to modify the mounting bracket to move the fluid cooler closer to the radiator.
Emanage should be the way to go although I am still experimenting with a modified standard ECU. I currently have 189 rwkw with stock cooler, stock turbo, panel filter, 0.8 bar boost and a good exhaust.
I have heard of a few people getting no extra power from a fmic with R34's unlike R33's and R32's which seem to pick up a bit automatically.
FYI, my GTT has been running EManage (minus ignition harness) for close to 2 years now and i am very happy with the result and response...no auto issues to date with crisp, fast changes but am considering auto mods such as altering stall etc. Current set-up: Hybrid FMIC, Hi-flowed standard turbo,Emanage,AVC-R (running 1 BAR), K&N Panel filter, Z32 AFM, 3" Dump, 3.5" JASMA exhaust and 3" CAT back, current power 220rwkW...am fitting Walbro internal 255lph fuel pump and searching for a set of injectors....
Cheers,
Michael
Thats weird Neo R34, I had the emanage setup with the Z32 but it wouldnt idle right.
Anyways here are some figure for u to think about:
At that time I had a front/cat back/e-01 boost controller and hks panel and i got about 170rwkw at about .85 bar.
Now I got the PFC/front mount/front and cat back/hks panel filter/ e-01 and I still only got about 180rwkw at about .7 bar.
I just cant seem to get power, anyways back to the topic. I agree best bang for buck is the Emanage. Neo mind me asking where u take ur car too?
ok. so greddy emanage seem to be a good option. I will look into that. thanx guys.
but what about stock R34 turbo n IC? Can they stand the daily grind of 200 rwkw or adding a FMIC and a hi flow/ new turbo(HKS 2530) are a more reliable option?
hoo@h- i think your questions are already answered in the above posts...look at the figures and mods, all will be revealed.
GroundRun- I am in Perth WA, if you are serious PM me and i will provide details. Check out for your own info the articles in back issues of HPI re: mods to GTT with manual and power gains...maybe your answers are there. Hope that helps.
Cheers,
Michael
Cheers,
Michael
Thanks Neo, looks like I can just follow your step and get that power figure i am looking for.
And, yes, I have got that HPI mag with the power figure n what mods are required, but just need to be sure that same mod apply to auto.
I guess I just want to know any other fellow auto r34 owner have achieved the result (200 rwkw) with a proven n reliable package. then I can just cut n paste it into me car. :P
by the way, I am in brissy, so if any1 know any good shop here that can do the sort of mod, please let me know. ta.
What's wrong with S-AFC? It may not have as many features, but it's still an option.
Nothing wrong with an SAFC...just thought the way he was talking he'd want some finer control of the ratios...and if he wanted to adjust ignition curves one of the only engine magement systems that'll work with the tiptronic is an e-manage.
Didn't want to tread on any SAFC toes :P
A full kit would be in your hands for $700 (e-manage + both harnesses + software) at the moment, and you can install it in less than a day easy
It handles boost cut and atmospheric BOV idle too...it really does have some good features.
You need access to a laptop...seriously though I used to have PC in the garage with a long cable on it that reached into the car....as long as you've got a computer nearby you can adjust the settings.
The benefit is it takes literally seconds to type in the new settings whereas PFC contollers are time consuming :(
Have a good read about it at www.mohdparts.com If you're considering getting one, get it from this guy (Mohammed) as his service is second to none..very helpful.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
