FWIW, I've used all GKTech, diff bushings are about 5 years old, still look the same (has probably seen a good coupe of hundred laps on the circuit too) Subframe bushing is about 1.5 years old now. Car has seen half a dozen track days since the subframe work and no bush deformation or cracking.
Hoping I don't ever have to touch it again (hoping I don't own the car long enough to change them again lol).
On 10/4/2023 at 10:01 AM, Predator1 said:
PLEASE DONT use WHITELINE BULLSHIT BUSHES.
My rear diff bushings were destroyed after just a few 1000 k's.. and yes, they were done by a reputable shop. Replaced with Nismo bushings and its perfect.
If the subframe is off, then it pays to replace all, especially if they have some age on them.
Thanks. Thats what i thought, the brand whiteline itself seems Sketchy and bad. Which one did you use for the subframe?
Sadly whiteline. I think for subframe bushings, it might be ok as it doesnt really 'move' much. Even though, having viewed the whiteline and Nismo subframe bushes, If I had known before, I would have happily splashed out a bit extra for the Nismo ones.
    • How much is it to re-uploster?  Well that's a "how longs a piece of string?" question !  And I answer thusly: "twice half its length! " . . . . . .  Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !  Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
