Stupidly the used import plate got defected when i was respraying the bay i ended up removing it not thinking much of it now i understand the entire car is voided and can't be registered without that sticker.
I've been trying to read there might be a chance if i can find the original shop that approved it to get another one
It's got a Workshop No.
An Approval number, Can't find much with that though. I've looked up the numbers and all and can't find any search results with it
Please tell me i'm not fu*ked here....
http://raws.dotars.gov.au/download/PDF/Placement of Used Import Plate.pdf
I was reading this and it states a used import plate must be metal so why are some purple? I've seen plenty of pictures online with them being purple
Expand
Purple anodised aluminium is metal.
I would suggest, unless you can actually get ahold of the original import workshop, you are indeed screwed. Most of the old shops are long closed.
Expand
Ahh okay it's like a purple plastic sticker tho
Dam that really sucks to hear.. The company only shut down 1 year ago they have changed names and are doing other related testing & services but it does not look like automotive
Wow so if i don't have luck with these guys this car is now worthless because of this stupid sticker?
Expand
I have another question i have another imported car that i brought registered and i'm trying to search both up on the website "http://raws.infrastructure.gov.au/rawswebpublic/RAWPubVehSearch.asp"
Neither of my imported cars are coming up on the website
I got a friend to check his imported car and it came up straight away..
Any idea why neither are coming up?
Does the car have an Australian vin number stamped onto it or plate (silver stainless) with said number riveted on? Has the car been previously registered and what state. I have heard people of getting imports re registered with missing import plates in certain states (not sure which) if the car had previously been registered in that state and had Aus vin.
I would contact your state authority and tell them the situation. Might take a few goes to actually find someone there who isn't a numpty and knows what they're on about.
What car is it by the way?
Early imports had metal compliance plates, later ones (around 2010on) had the purple sticker.
Expand
There should be two plates. Pink plastic plate is the compliance sticker. The metal plate is the new Australian VIN number (6U9000-ECR33XXXX) which should pinned on top of the old japanese vin on the firewall.
In your situation i would recommend contacting a local compliance workshop. explain your situation and they might be able to liase with DOTARS and issue a new sticker for a fee of course.
Expand
Someone just told me in Victoria he got new import plate for 2 cars that the import plate was defected
Yes it has a build plate & A separate Vin plate (both stainless)
Yes i've been previously registered in QLD.
I have 2 imports here one is a 95 which has a green metal import plate, my other car is a 97 which has a purple sticker import plate which i'm looking at getting that one replaced.
I guess i'll have to ring around, Do i just start with like Department of QLD?
With that being said, I've got 2 imports here and i looked up both VINS here - http://raws.infrastructure.gov.au/rawswebpublic/RAWPubVehSearch.asp
Neither come up lmao. Both have been registered before
I got my friend to check his import and it came up, So now i'm really confused. I guess i'll be calling the Gov about both of my cars.
Edited by connor055
Expand
Yep i've got a build plate + a Long vin number separate plate + Import purple sticker
Yep i've got to call around for sure. Thanks so much i am really stressing over this. This will be a very very costly mistake if i can't fix it.
Edited by connor055
  On 01/10/2023 at 4:38 AM, Duncan said:
My stagea doesn't come up on that link when i search by rego, did come up for VIN only.
I would contact DOTARS, not state, because it is the feds who issued the plates
Expand
Atleast it came up i did both my cars via VIN and nothing.
Yeah okay, thankyou i'll give it a go
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
