Stupidly the used import plate got defected when i was respraying the bay i ended up removing it not thinking much of it now i understand the entire car is voided and can't be registered without that sticker.
I've been trying to read there might be a chance if i can find the original shop that approved it to get another one
It's got a Workshop No.
An Approval number, Can't find much with that though. I've looked up the numbers and all and can't find any search results with it
Please tell me i'm not fu*ked here....
http://raws.dotars.gov.au/download/PDF/Placement of Used Import Plate.pdf
I was reading this and it states a used import plate must be metal so why are some purple? I've seen plenty of pictures online with them being purple
Purple anodised aluminium is metal.
I would suggest, unless you can actually get ahold of the original import workshop, you are indeed screwed. Most of the old shops are long closed.
Ahh okay it's like a purple plastic sticker tho
Dam that really sucks to hear.. The company only shut down 1 year ago they have changed names and are doing other related testing & services but it does not look like automotive
Wow so if i don't have luck with these guys this car is now worthless because of this stupid sticker?
I have another question i have another imported car that i brought registered and i'm trying to search both up on the website "http://raws.infrastructure.gov.au/rawswebpublic/RAWPubVehSearch.asp"
Neither of my imported cars are coming up on the website
I got a friend to check his imported car and it came up straight away..
Any idea why neither are coming up?
Does the car have an Australian vin number stamped onto it or plate (silver stainless) with said number riveted on? Has the car been previously registered and what state. I have heard people of getting imports re registered with missing import plates in certain states (not sure which) if the car had previously been registered in that state and had Aus vin.
I would contact your state authority and tell them the situation. Might take a few goes to actually find someone there who isn't a numpty and knows what they're on about.
What car is it by the way?
Early imports had metal compliance plates, later ones (around 2010on) had the purple sticker.
There should be two plates. Pink plastic plate is the compliance sticker. The metal plate is the new Australian VIN number (6U9000-ECR33XXXX) which should pinned on top of the old japanese vin on the firewall.
In your situation i would recommend contacting a local compliance workshop. explain your situation and they might be able to liase with DOTARS and issue a new sticker for a fee of course.
Someone just told me in Victoria he got new import plate for 2 cars that the import plate was defected
Yes it has a build plate & A separate Vin plate (both stainless)
Yes i've been previously registered in QLD.
I have 2 imports here one is a 95 which has a green metal import plate, my other car is a 97 which has a purple sticker import plate which i'm looking at getting that one replaced.
I guess i'll have to ring around, Do i just start with like Department of QLD?
With that being said, I've got 2 imports here and i looked up both VINS here - http://raws.infrastructure.gov.au/rawswebpublic/RAWPubVehSearch.asp
Neither come up lmao. Both have been registered before
I got my friend to check his import and it came up, So now i'm really confused. I guess i'll be calling the Gov about both of my cars.
Edited by connor055
Yep i've got a build plate + a Long vin number separate plate + Import purple sticker
Yep i've got to call around for sure. Thanks so much i am really stressing over this. This will be a very very costly mistake if i can't fix it.
Edited by connor055
2 hours ago, Duncan said:
My stagea doesn't come up on that link when i search by rego, did come up for VIN only.
I would contact DOTARS, not state, because it is the feds who issued the plates
Atleast it came up i did both my cars via VIN and nothing.
Yeah okay, thankyou i'll give it a go
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
