Hey All!
I know their is threads about this topic but I can’t seem to find one about what’s happening to my HR34 Skyline.
Basically Brake Lights are on when the car is turned Off even when a new brake switch Rubber is Installed.
When I press on the brake I hear a little clicking noise like a relay sound where the Automatic Shifter is located.
have anyone experienced it before?  I would like some advice before I take all my trims apart to find a relay?
thank you!
4 hours ago, Seefou said:
Hey All!
thank you!
The sound you're hearing is the shift interlock device. You have to press the brake to shift out of park. There is a stop lamp switch in addition to the little rubber grommet. Test the switch and see if it's working as intended. A new one is pretty cheap.
  • Like 1
The Stop lamp switch, Are you referring to the brake light switch?
I removed the wire connected to the switch and the lights are still on.
I will put the volt meter tomorrow and try it on.
But how is the power getting through even when unplugged?
im trying to find a wiring diagram but unfortunately I can’t.
5 hours ago, GTSBoy said:
The click won't be a relay. The click will likely just be in the pivot/spring of the pedal.
The switch is likely collapsed. Break out the multimeter and fault-find.
I tried taking off every 10a fuse to see if lights will turn off but it was a no go. Tried both fuse box.
I unplugged the wire from the switch and the lights was still on.
im wondering if possibly there is a relay that might be stuck and always open?
So, start at the brake lamp itself, probe the loom with the multimeter, follow the wiring back until you find where the power is getting into it.
If you have disconnected the spot from whence the power is supposed to come, and you still have power, then the power is likely coming in from a spot with damaged insulation in the loom.
There is no relay.
  • Like 1
There is no relay.
Excellent thank you! Will definitely wake up early and start there!
The great news is lights turn off when Unplugged from the lamp.
but it’s weird that id doesn’t turn off when you take out the Tail Fuse from the fuse box.
wondering if by having the break lights on for who knows how long until it drained my battery, sometimes melted in the circuit?
I guess there’s no choice but following the wire 😅 I’ll keep you updated.
9 minutes ago, Duncan said:
or for that matter, the fog lights.
Every lights are off, I also took out the fuses and the Brake lights was still on.
I unplugged the Brake stopper switch and their was still power to the lights.
I unplugged the lights directly and it turned off.
so the question I should ask my self is is it just wires from lamp to brake switch or theirs something else in the circuit that is related?
the only weird thing is when I removed the fuse for the Tail lamp the lights was still on 🤷🏻‍♂️
You shouldn't ask these questions. You should instead open up the wiring diagram and follow the circuits. You will see that the tail light fuse has nothing to do with the brake lights. You will see that the brake lights are their own thing.
The other thing to remember is that typically, such circuits in cars are supplied with 12V out at the load itself and that 12V comes all the way back to the switch and the switch connects to ground when closed. This we call "earth switching". The power is not "supplied" by the switch. Power is always available. The switch gives earth to the circuit.
But this is where you really need the wiring diagram, because not all circuits in cars are earth side switched, and a novice can very easily get very confused.
  • Like 1
Now it makes more sens in my head. I was getting confused. Thank you for lighting things up for me.
I’ve been trying to find the wiring diagram since last week but unfortunately haven’t find anything online.
They've been posted on these and other forums before. The R34 and R33 workshop manuals also have useful wiring diagrams.
Have a look at
https://www.nicoclub.com/nissan-service-manuals
https://www.scribd.com/doc/5332929/Nissan-Skyline-R34-Workshop-Manual-English
Even the R32 GTR wiring diagram, that I have scanned and posted on here, will help, because the circuit for the brake lights is probably all same same. Wire colours, fuse numbers, etc, will possibly be different. But at least you can look at it to see how things are laid out.
  • Like 3
Have a look at
You are awesome!
Thank you so much!
I needed this so much! 🙏🏼
  • 4 weeks later...
Update!!! I feel dumb but hey it’s fixed! 😄
so after many weeks and all of research for a wiring diagram, having bad weather and being busy it helped me to not take the interior a part to find the issue lol! Luckily!
I met someone named Michael he said to me since it’s a Automatic transmission you have two switch.
one for the shift lock and one for the brake light.
so guess what!!
I changed the rubber on the shift lock switch that is right beside the brake light switch.
both have fallen a part and me well, I thought their was only one switch 😅
Green arrow is where I changed the rubber and the Red Arrow is where I completely failed to noticed.
  • Like 2
  • Thanks 1
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
