Seefou Posted October 1, 2023 Share Posted October 1, 2023 Hey All! I know their is threads about this topic but I can’t seem to find one about what’s happening to my HR34 Skyline. Basically Brake Lights are on when the car is turned Off even when a new brake switch Rubber is Installed. When I press on the brake I hear a little clicking noise like a relay sound where the Automatic Shifter is located. have anyone experienced it before? I would like some advice before I take all my trims apart to find a relay? thank you! Link to comment https://www.sau.com.au/forums/topic/484979-brake-lights-on-when-car-turned-off-even-when-new-brake-switch-rubber-installed/ Share on other sites More sharing options...
GTSBoy Posted October 1, 2023 Share Posted October 1, 2023 The click won't be a relay. The click will likely just be in the pivot/spring of the pedal. The switch is likely collapsed. Break out the multimeter and fault-find. 1 Link to comment https://www.sau.com.au/forums/topic/484979-brake-lights-on-when-car-turned-off-even-when-new-brake-switch-rubber-installed/#findComment-7983414 Share on other sites More sharing options...
joshuaho96 Posted October 1, 2023 Share Posted October 1, 2023 4 hours ago, Seefou said: Hey All! I know their is threads about this topic but I can’t seem to find one about what’s happening to my HR34 Skyline. Basically Brake Lights are on when the car is turned Off even when a new brake switch Rubber is Installed. When I press on the brake I hear a little clicking noise like a relay sound where the Automatic Shifter is located. have anyone experienced it before? I would like some advice before I take all my trims apart to find a relay? thank you! The sound you're hearing is the shift interlock device. You have to press the brake to shift out of park. There is a stop lamp switch in addition to the little rubber grommet. Test the switch and see if it's working as intended. A new one is pretty cheap. 1 Link to comment https://www.sau.com.au/forums/topic/484979-brake-lights-on-when-car-turned-off-even-when-new-brake-switch-rubber-installed/#findComment-7983420 Share on other sites More sharing options...
Seefou Posted October 2, 2023 Author Share Posted October 2, 2023 4 hours ago, joshuaho96 said: The sound you're hearing is the shift interlock device. You have to press the brake to shift out of park. There is a stop lamp switch in addition to the little rubber grommet. Test the switch and see if it's working as intended. A new one is pretty cheap. The Stop lamp switch, Are you referring to the brake light switch? I removed the wire connected to the switch and the lights are still on. I will put the volt meter tomorrow and try it on. But how is the power getting through even when unplugged? im trying to find a wiring diagram but unfortunately I can’t. Link to comment https://www.sau.com.au/forums/topic/484979-brake-lights-on-when-car-turned-off-even-when-new-brake-switch-rubber-installed/#findComment-7983425 Share on other sites More sharing options...
Seefou Posted October 2, 2023 Author Share Posted October 2, 2023 5 hours ago, GTSBoy said: The click won't be a relay. The click will likely just be in the pivot/spring of the pedal. The switch is likely collapsed. Break out the multimeter and fault-find. I tried taking off every 10a fuse to see if lights will turn off but it was a no go. Tried both fuse box. I unplugged the wire from the switch and the lights was still on. im wondering if possibly there is a relay that might be stuck and always open? Link to comment https://www.sau.com.au/forums/topic/484979-brake-lights-on-when-car-turned-off-even-when-new-brake-switch-rubber-installed/#findComment-7983426 Share on other sites More sharing options...
GTSBoy Posted October 2, 2023 Share Posted October 2, 2023 1 hour ago, Seefou said: I unplugged the wire from the switch and the lights was still on. So, start at the brake lamp itself, probe the loom with the multimeter, follow the wiring back until you find where the power is getting into it. If you have disconnected the spot from whence the power is supposed to come, and you still have power, then the power is likely coming in from a spot with damaged insulation in the loom. There is no relay. 1 Link to comment https://www.sau.com.au/forums/topic/484979-brake-lights-on-when-car-turned-off-even-when-new-brake-switch-rubber-installed/#findComment-7983430 Share on other sites More sharing options...
MBS206 Posted October 2, 2023 Share Posted October 2, 2023 Turn the parking lights off... Link to comment https://www.sau.com.au/forums/topic/484979-brake-lights-on-when-car-turned-off-even-when-new-brake-switch-rubber-installed/#findComment-7983432 Share on other sites More sharing options...
Duncan Posted October 2, 2023 Share Posted October 2, 2023 1 hour ago, MBS206 said: Turn the parking lights off... or for that matter, the fog lights. Link to comment https://www.sau.com.au/forums/topic/484979-brake-lights-on-when-car-turned-off-even-when-new-brake-switch-rubber-installed/#findComment-7983438 Share on other sites More sharing options...
Seefou Posted October 2, 2023 Author Share Posted October 2, 2023 1 hour ago, GTSBoy said: So, start at the brake lamp itself, probe the loom with the multimeter, follow the wiring back until you find where the power is getting into it. If you have disconnected the spot from whence the power is supposed to come, and you still have power, then the power is likely coming in from a spot with damaged insulation in the loom. There is no relay. Excellent thank you! Will definitely wake up early and start there! The great news is lights turn off when Unplugged from the lamp. but it’s weird that id doesn’t turn off when you take out the Tail Fuse from the fuse box. wondering if by having the break lights on for who knows how long until it drained my battery, sometimes melted in the circuit? I guess there’s no choice but following the wire 😅 I’ll keep you updated. Link to comment https://www.sau.com.au/forums/topic/484979-brake-lights-on-when-car-turned-off-even-when-new-brake-switch-rubber-installed/#findComment-7983439 Share on other sites More sharing options...
Seefou Posted October 2, 2023 Author Share Posted October 2, 2023 9 minutes ago, Duncan said: or for that matter, the fog lights. Every lights are off, I also took out the fuses and the Brake lights was still on. I unplugged the Brake stopper switch and their was still power to the lights. I unplugged the lights directly and it turned off. so the question I should ask my self is is it just wires from lamp to brake switch or theirs something else in the circuit that is related? the only weird thing is when I removed the fuse for the Tail lamp the lights was still on 🤷🏻♂️. Link to comment https://www.sau.com.au/forums/topic/484979-brake-lights-on-when-car-turned-off-even-when-new-brake-switch-rubber-installed/#findComment-7983442 Share on other sites More sharing options...
GTSBoy Posted October 2, 2023 Share Posted October 2, 2023 15 minutes ago, Seefou said: so the question I should ask my self is is it just wires from lamp to brake switch or theirs something else in the circuit that is related? the only weird thing is when I removed the fuse for the Tail lamp the lights was still on 🤷🏻♂️. You shouldn't ask these questions. You should instead open up the wiring diagram and follow the circuits. You will see that the tail light fuse has nothing to do with the brake lights. You will see that the brake lights are their own thing. The other thing to remember is that typically, such circuits in cars are supplied with 12V out at the load itself and that 12V comes all the way back to the switch and the switch connects to ground when closed. This we call "earth switching". The power is not "supplied" by the switch. Power is always available. The switch gives earth to the circuit. But this is where you really need the wiring diagram, because not all circuits in cars are earth side switched, and a novice can very easily get very confused. 1 Link to comment https://www.sau.com.au/forums/topic/484979-brake-lights-on-when-car-turned-off-even-when-new-brake-switch-rubber-installed/#findComment-7983447 Share on other sites More sharing options...
Seefou Posted October 2, 2023 Author Share Posted October 2, 2023 Now it makes more sens in my head. I was getting confused. Thank you for lighting things up for me. I’ve been trying to find the wiring diagram since last week but unfortunately haven’t find anything online. Link to comment https://www.sau.com.au/forums/topic/484979-brake-lights-on-when-car-turned-off-even-when-new-brake-switch-rubber-installed/#findComment-7983449 Share on other sites More sharing options...
GTSBoy Posted October 2, 2023 Share Posted October 2, 2023 They've been posted on these and other forums before. The R34 and R33 workshop manuals also have useful wiring diagrams. Have a look at https://www.nicoclub.com/nissan-service-manuals https://www.scribd.com/doc/5332929/Nissan-Skyline-R34-Workshop-Manual-English Even the R32 GTR wiring diagram, that I have scanned and posted on here, will help, because the circuit for the brake lights is probably all same same. Wire colours, fuse numbers, etc, will possibly be different. But at least you can look at it to see how things are laid out. 3 Link to comment https://www.sau.com.au/forums/topic/484979-brake-lights-on-when-car-turned-off-even-when-new-brake-switch-rubber-installed/#findComment-7983451 Share on other sites More sharing options...
Seefou Posted October 2, 2023 Author Share Posted October 2, 2023 19 minutes ago, GTSBoy said: They've been posted on these and other forums before. The R34 and R33 workshop manuals also have useful wiring diagrams. Have a look at https://www.nicoclub.com/nissan-service-manuals https://www.scribd.com/doc/5332929/Nissan-Skyline-R34-Workshop-Manual-English Even the R32 GTR wiring diagram, that I have scanned and posted on here, will help, because the circuit for the brake lights is probably all same same. Wire colours, fuse numbers, etc, will possibly be different. But at least you can look at it to see how things are laid out. You are awesome! Thank you so much! I needed this so much! 🙏🏼 Link to comment https://www.sau.com.au/forums/topic/484979-brake-lights-on-when-car-turned-off-even-when-new-brake-switch-rubber-installed/#findComment-7983453 Share on other sites More sharing options...
Seefou Posted October 25, 2023 Author Share Posted October 25, 2023 Update!!! I feel dumb but hey it’s fixed! 😄 so after many weeks and all of research for a wiring diagram, having bad weather and being busy it helped me to not take the interior a part to find the issue lol! Luckily! I met someone named Michael he said to me since it’s a Automatic transmission you have two switch. one for the shift lock and one for the brake light. so guess what!! I changed the rubber on the shift lock switch that is right beside the brake light switch. both have fallen a part and me well, I thought their was only one switch 😅. Green arrow is where I changed the rubber and the Red Arrow is where I completely failed to noticed. 2 1 Link to comment https://www.sau.com.au/forums/topic/484979-brake-lights-on-when-car-turned-off-even-when-new-brake-switch-rubber-installed/#findComment-7984046 Share on other sites More sharing options...
