good day,
I am looking for a new stock turbo and I have found a few but they are listed as:
Turbocharger For Nissan RB25DET Skyline R33 45V1 OP6
https://www.ebay.com/itm/265859366624
so would this be a correct replacement for a stock RB25DET NEO engine turbo as well
or are the turbos different from the Rb25det non NEO engines?
https://www.sau.com.au/forums/topic/484991-proper-stock-turbo-98-r34-gtt-neo/
1 hour ago, JC71 said:
good day,
RB25DET vs DET NEO have different turbos. This thread talks about the differences:
Personally I would not run these turbos without replacing both the nylon compressor and ceramic turbine. It will increase turbo lag but that is fine if it means there's no risk it sends ceramic shards backwards from internal EGR or a bunch of compressor chunks through your intake tract.
This is problematic. The R33 did not have the OP6 exhaust housing. So the vendor does not really know what they're talking about, regardless of whether the actual turbo is "correct" for either R33 or R34. First warning sign.
And again, the differences matter. Plus something else.
  1. R34 turbos do not have plastic comp wheels. Alloy.
  2. There is very little to no risk of ceramic turbine making its way back into the engine on a single turbo. That is pretty strictly a GTR thing, which must come down to the straight shot from the turbine scroll back into the exhaust manifold and port opposite. It is essentially unheard of on single turbo engines.
Nevertheless, I would concur with Joshua. Why would anyone want to spend money to put the stock turbo back onto an RB? It's just mental. Buy a decent upgrade, win at life.
  • Like 1
  • Thanks 1
I was just going off what that post mentioned, which is the early AA100 was still plastic compressor, then all later revisions were alloy. It's good to know that the risk is lower on the single turbos but still it's definitely a day-ruining event if a turbo lets go.
Edited by joshuaho96
Happened to me last month. Finally, after 10+ years of running enough boost to put it at risk.
A small pompf noise. A lot of blue smoke. A broken oxy sensor, and a short drive to my mechanic's shop, seeing as I was just around the corner when it died. And thousands of $$ spent since! Not day ruining, but bad enough.
2 hours ago, JC71 said:
I will be both wheels with steel before putting on car,
Well, you certainly wouldn't buy a new OEM Hitachi turbo to then throw away the entire centre. You've already got both the housings you need to have it recored with something with "steel" wheels (actually not steel).
I don't have either housing to have it recored....
I would buy new or really nice used (of the correct version ) and plan to send it to Hyper gear to have high flow service and replace the wheels with "steel" (to replace what ever is there, composite/ceramic/plastic/nylon) I will keep searching cause if there are some of these out there (45V1) new.....there has to be the correct style (45V4)  out there, new as well.
Edited by JC71
If you want a highflow from HG (or anyone) you only need housings. Literally, the core can be completely shot. There is no point in buying a good condition, let alone new, turbo.
In fact, if you just pay Tao a little extra, he will supply a set of housings from a blown turbo.
But if you're not in possession of any turbo at all.....just buy a new HG turbo outright? I mean, it's not as if am HG highflow goes right back exactly where the stock turbo came from. The exhaust housing location is the same, but because the core is much smaller, the compressor housing moves backward, requiring changes to the inlet plumbing and all the oil and water lines. So, if you're going to do that, and have to pay for housings, you may as well just buy a different turbo.
  • Like 1
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
