Hey guys,
I've recently manual swapped my RB25DE Skyline and have put a RB20E gearbox in.
The RB20E gearbox is out of a series 1 R33 and my R33 is a series 2.
Since doing the swap, I've noticed my speedo is reading just over double and the odometer is rolling the ks over faster. I have kept the original auto cluster in for now untill I can source a manual one.
Could this be because of the transducer/speedo sensor? If so, which one would I need to get to get an accurate speed? An RB20E as this is what the gearbox is, or a RB25DE?
Or could the issue be something else entirely?
Cheers
13 minutes ago, GTSBoy said:
Surely they're the same skinny gearbox? Just put the sender from the original box into the new one?
The original one from the auto gearbox is bigger in diameter unfortunately. That was the first thing I checked out
39 minutes ago, GTSBoy said:
Ah sorry. I totally vagued on the point that it was a manual swap.
So yes, you just need the correct speed sensor to suit the dash. So skinny box sender. Probably the same S1/S2 anyway.
No worries. So do you reckon a RB25DE speed sensor would sort the speedo out? As there is already a RB20E speed sensor in the gearbox causing an inaccurate reading. Would a RB25DE speed sensor fit straight into a RB20E gearbox? Also, are maunal and auto speed sensors the same size?
Well......you would have to hope so, otherwise your only fix is going to be electronic. That's doable, but, non-trivial. We can address that later, if need be.
The problem is that the speed sensor relies on 2 gears. One in the box, one on the end of the speed sensor. It would obviously be impossible for them to have 2 different gear ratios without BOTH gears being different. The fact that the error is exactly 50% (or 200%) of the expected/required reading would suggest that the difference is in the number of poles inside the senor. A 2 pole generator would produce half as many pulses per rev as a 4 pole generator. I'd be willing to bet that that's the difference. Problem is, I don't know that they actually did that.
Anyway, assuming that the difference is internal to the sensor, then the pinion gear on the two sensors should be the same and yes, either one would physically fit into either box and turn at the "right" speed.
20 minutes ago, robbo_rb180 said:
I've been using the Jaycar one in the stagea for more than 10 years, still working perfectly
TBH in my experience with the Jaycar module was a little different. I was using it in the middle of the car ECU to the cluster. It worked, but it only kicked in at about 30-40kmh. So anything under that would read 0kmh. It was also delayed. It may work for something int he same family that it just needs to do something like 'halve'
The dakota digital one worked perfectly in my application, and can be used for many, many, many different inputs and outputs.
  • 2 months later...
Just thought I'd post an update for anyone reading this thread in future that may have the same issue. I have the odometer reading correctly now after sourcing a series 2 speedo sensor (RB25DE) and putting it in the gearbox (RB20E). Cheers for all the imput guys 👍
  • Like 1
  • Thanks 1
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
