Hey guys,
I've recently manual swapped my RB25DE Skyline and have put a RB20E gearbox in.
The RB20E gearbox is out of a series 1 R33 and my R33 is a series 2.
Since doing the swap, I've noticed my speedo is reading just over double and the odometer is rolling the ks over faster. I have kept the original auto cluster in for now untill I can source a manual one.
Could this be because of the transducer/speedo sensor? If so, which one would I need to get to get an accurate speed? An RB20E as this is what the gearbox is, or a RB25DE?
Or could the issue be something else entirely?
Cheers
13 minutes ago, GTSBoy said:
Surely they're the same skinny gearbox? Just put the sender from the original box into the new one?
The original one from the auto gearbox is bigger in diameter unfortunately. That was the first thing I checked out
39 minutes ago, GTSBoy said:
Ah sorry. I totally vagued on the point that it was a manual swap.
So yes, you just need the correct speed sensor to suit the dash. So skinny box sender. Probably the same S1/S2 anyway.
No worries. So do you reckon a RB25DE speed sensor would sort the speedo out? As there is already a RB20E speed sensor in the gearbox causing an inaccurate reading. Would a RB25DE speed sensor fit straight into a RB20E gearbox? Also, are maunal and auto speed sensors the same size?
Well......you would have to hope so, otherwise your only fix is going to be electronic. That's doable, but, non-trivial. We can address that later, if need be.
The problem is that the speed sensor relies on 2 gears. One in the box, one on the end of the speed sensor. It would obviously be impossible for them to have 2 different gear ratios without BOTH gears being different. The fact that the error is exactly 50% (or 200%) of the expected/required reading would suggest that the difference is in the number of poles inside the senor. A 2 pole generator would produce half as many pulses per rev as a 4 pole generator. I'd be willing to bet that that's the difference. Problem is, I don't know that they actually did that.
Anyway, assuming that the difference is internal to the sensor, then the pinion gear on the two sensors should be the same and yes, either one would physically fit into either box and turn at the "right" speed.
20 minutes ago, robbo_rb180 said:
I've been using the Jaycar one in the stagea for more than 10 years, still working perfectly
TBH in my experience with the Jaycar module was a little different. I was using it in the middle of the car ECU to the cluster. It worked, but it only kicked in at about 30-40kmh. So anything under that would read 0kmh. It was also delayed. It may work for something int he same family that it just needs to do something like 'halve'
The dakota digital one worked perfectly in my application, and can be used for many, many, many different inputs and outputs.
  • 2 months later...
Just thought I'd post an update for anyone reading this thread in future that may have the same issue. I have the odometer reading correctly now after sourcing a series 2 speedo sensor (RB25DE) and putting it in the gearbox (RB20E). Cheers for all the imput guys 👍
  • Like 1
  • Thanks 1
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
    • A seat I find stupidly comfortable to sit in is the one in a friend's Merc Race Car. It even has the huge wings that wrap around your head. Best ever. Only issue is climbing through his scaffolding he put up in the doorway of the car... Ha ha ha. I sat in that seat for a couple of hours doing wiring. Another stupid comfortable seat I find, especially if my back is aching, is my OMP fixed back bucket seat too. I'll just sit on it when I'm exhausted in the garage sometimes to relax!
    • I just got off the phone with Dean from Vosta in Brisbane. They are the ones that do the replica seats and they have a shop full of seats for my to try out. Lovely guy.  I haven't decided whether to go genuine or replicas, I'm leaning towards Genuine at this point but who knows.  Also thinking the STRADIAs are the way to go VS the GIAS since they have a lower hip edge and would be easier to get into. Don't really like the idea of arm rests on the models to the right of this diagram either, maybe they can be removed?
    • From my own first hand experience, keeping power for a fun Street able skyline down at a responsive low 200 wheel KW, is the best. It makes it super drive able through the twisties, you're not just smashing mass wheel spin, or only able to open the throttle for a split second before being at absurd speeds. That said, plenty of people like being morons at more than double the speed limit on public roads and hence are happy with 600whp and seeing 200kmh fly up frequently and fast. Also, at that low 200, a GTR can still do a decent quarter mile, and with a bit of fancy  clutch work (foot, not the parts) can still beat many many cars in a traffic light gp, even in the wet.
