Looking to hear from the guys who are assembling their own RBs in Melbourne.
Does anyone have a machinist they know and trust who could provide some level of advice and complete the machine work, then send me off to assemble it myself?
I should state:
- I understand that engine builders make their money by building engines themselves. Not expecting anything for free, in fact I'm keen to pay them.
- Given I will be assembling the engine, I accept all responsibility if in the event it was to fail (would happily put this in writing).
The idea behind this is to get good at building my own engines, enjoy the process and become self-sufficient. I have built an RB25 myself almost 10 years ago and I was a mechanic for several years, however I recognise I'm not an engine builder.
I've dropped off and picked this block up from two workshops already where they promise to do the work, nothing happens for 3 months and I get over it. I just want out of this cycle and to drive/enjoy my car.
any help much appreciated 🙏🏼
  • Like 1
It was many years ago I got my engine machining done but I had a very good experience with Headspec in Clayton.  Frank was the guy running the show back then and I think it was Michael who was working for him (may be in charge now??).  They were great to deal with and everything was done as per my requests and expectations.
Nothing wrong with wanting to do it yourself and as you say, it's all on you if it turns to shit!
Good luck!!
Frank and Michael are still around, and are still great. However, like most people who are still around and still great, they're very busy. So you may have a 3 month wait purely because of the backlog of things they already have on the go.
I always say a blown up RB is a 1 year process :D. But to be fair, my experience with Headspec was quite a lot of waiting until they got to my job, then when they did - it was completed in a couple of weeks. So I suppose there's plenty of work for competent engine builders out there.
I have met Frank and Michael from Headspec. They are both lovely guys, gave me plenty of time and were always happy to chat and answer questions when I saw them in person. They have done some fab work for me previously. Unfortunately, they were the second workshop I left the block with. Potentially they're just too busy. One of the engines he was working on was being built over a 12 month period (also an RB). The block sat there for three months just to have them assess the block and quote a build (never happened). I actually felt quite comfortable with them and thought they would do a great job. I'm just not in a position to wait 12 months or someone to build this engine :(
Righto, bummer!  That makes it tough.  One thing Covid has taught us all, you want something bad enough, you gotta wait!
Could be worth taking it out of town?  Somewhere regional like Bendigo or Ballarat as they MAY be slightly less backlogged?  No one here in Shepp I would necessarily recommend unfortunately....
I hope you get it sorted out.
  • 1 month later...
I reckon if you were to find a retired engine machinist who can mentor you, you’d be able to fill in the gaps with your own skills.
maybe have some conversations with the guys who are running the shops now about who they did their apprenticeships with?
    • Cheapest option, find a NEO head. Put in good springs, decent cams, and send it to the moon. I rev mine to 8600RPM, gets me about 232km/h down the main straight at SMSP bouncing off the limiter in 4th. I've never dared to grab 5th 🥲
    • Gday mate, Personally in my car i run 450kw in an s2 rb25 so also hydraulic lifters and have always run it to 7500 RPM and using some baby 256 poncams with new but stock springs and retainers. While i cant speak on any experience with solid lifters i personally have had no issues with my hydraulic lifters which were just cleaned and set in an oil bath before assembly over 7 years ago. Over 8k RPM is cool IMO and if you are using the stock gearbox or just a box with longer ratios the higher rpm certainly could aid to maintain boost into the next gear as that was always something i struggled with as i have a 3582r also but a hypergear equivalent could aid that issue. In summary i would make a choice on the cam you want to use first then decide which springs and retainers work best with it and then you can toss up if you really need the solid lifters, if the car is mainly street i would learn towards keeping the hydraulic lifters as when installed properly and nothing too hektik going on around them they do the trick.
    • Yucky. Things haven't gotten any better though. Now you have Emerson and Honeywell pushing these massive DCS/Scada things with proprietary hardware. They're not a PLC, they're not a computer, they're a...distibuted PLCish/DCSish monster of thing, that only they can program because they make the barriers to entry for anyone else so fricking high. And their developers are all located in the third/developing world (and India, in case anyone does not include that place in that category) and there are terrible failings of the ESl variety, of the care and common sense variety, and f**king forget about Functional Safety. Not a one of them has any idea what it means to comply with an IEC 615xx series standard.
    • All of the ECU grounds are to the chassis, the IGN grounds are to the cylinder head and i believe all the OEM body harness are left in original locations, im trying to work out if i can tell if the sensor voltage itself is losing any power to it from the very low ECU voltage. But yeah a manual pressure gauge will help in picking which path to actually chase. Also please dont bully my wiring plan i never designed it to be universally understood hopefully it still can make sense to you, im a wiring virgin.  1 thing i have just noticed the pressure sensor in question relays both pressure and temperature, the temperature reading holds nice and steady despite the low ecu voltage but the pressure reading is the one that jumps around alot so maybe it is really a pressure issue? wiring plan.xlsx
