fresh build only making 210hp at 19Psi of boost. Very lazy doesn’t build boost till 5000rpm.
So my car just got broken in on the dyno. Fresh build with Manley 86.5mm pistons 9:0:1, Manley h beam rods, BC 264/264 cams. ARP hardware, ACL bearings, HKS GTIII-SS turbos. 3 bar map / Haltech 2500 ECU. After breaking in they threw it on the dyno and tuned it.  checked everything. No boost leaks, no exhaust leaks, no shop rags stuck in intercooler piping. It made 210 at 14psi then they increased boost to 19psi and increased injector duty cycle and still the same 210hp. leak down test 10-15%, compression 120 120 140 140 140 140, waste gates are properly adjusted and car hits target boost level. Not sure what it could be. Do not have dyno sheet from shop. They’re going to take it out on the street and data log tomorrow. Anyone have an idea of what could be wrong?
Edited by Brodys_92GTR
21 minutes ago, Duncan said:
I'd start with the timing; both the belt itself and potentially any adjustable cam gears.
Or, maybe that is why no-one uses journal bearing turbos any more :)
He already asked this question earlier on a Facebook group, I have the same turbos and in 4th gear it should be at 10 psi around 3200 RPM. Uneven compression across the the cylinders is not a good sign, especially by that much. I would also question the cam timing, it's possible the cam centerlines were not cut correctly or some other issue with the aftermarket cams, supposedly Brian Crower has QC/QA issues.
  • 3 months later...
Um, yeah. No. I have GTIII-SS turboes. Just dynoed on Sunday. 446rwhp/387ft-lbs @ 18psi/1.24bar. Very fun to drive. Busted my hump putting her together. Impressed by the turboes. The JB and single turbo nonsense Australians are infamous for needs to die on the vine.
We have only been playing with gtrs for 30 years and build the best in the world, what would we know?
  • Like 3
Congrats on being experts on ONE chassis. Now bow down to GM and Ford for even branching out to your continent. Anyway, I'm not going to go tit for tat with you. Got some ex-military buddies out there in AU and don't want to give off the impression that I dislike Australians. Twin scroll single conversions are not the end all be all because some dude from Motive who makes videos said so.
U will probably find that the majority of people on here think he is f*#kwit
  • Like 4
Good. glad to know we feel the same way about each other. I created an account to share some info, not battle the Australian single-turbo hivemind/echo chamber. Have fun!
Glad you are happy with your choice, do you have a dyno graph to share (and, what dyno was it on?)
My direct experience is 20+ years racing on journal bearing turbos due to class rules, and watching those with modern BB singles on the same motor driving away in a straight line, is your experience one dyno pull?
I'd expect that coming to the forums and telling everyone their experience is "nonsense" will get you a bit of push back.
  • Like 2
Sure. I just posted them in the GTIII-SS topic. We ran seven pulls on dyno packs. I'm not arguing BB vs JB here. That is subjective, regardless. I'm arguing that they aren't "junk". Same goes for "twins in the bin" talk. Basically, go and tell all of Japan and the US that their cars are trash because your nation's tuners have decided on such. It's nonsense because this "my way or it's trash" that gets peddled on here is tiresome. Of course I expect pushback when it's 5-7 years of an echo chamber. It's like the MAF vs MAP conversation. From an installation perspective having did all the work myself and never bringing my GTR to a mechanic in five years, single is the preferred option. I won't argue that. But driveability and "fun", I prefer the twins. And no, the Motive video with a borderline PRP salesman saying "this is better" won't convince me.
I think there's some silliness going on with THE_BEST option being lauded as the only option, and second, third, fourth best options which may be 5% worse being regarded as utter junk.
Logically though, if you have a stock GTR, and you want to update it's forced induction system, you have an option of purchasing one turbo and a manifold, or two turbos and a manifold, or two turbos on the stock manifold(s).
If you're gonna buy two, one would hope that you'd get any benefit at all out of spending double the money, but uh, that's not what happens.
I hated that Andrew Hawkins video purely because he uses a single/double combination from completely different generations of turbo and makes conclusive decisions based on that. He's gotten a lot better since then in his objectivity to be honest.
Would love to see what would have happened if it was a GTX3582 and Twinscroll that he used vs two Borg Warner EFR's and a fullrace manifold making the same target power at same target boost, you know, like some adherence to the scientific method when doing things.
But would probably still find the same, spending much more money for potentially no benefit at all is why people would be against it.
The turbo is the only thing on these cars that produces power, so everyone gets a bee in their bonnet when people spend tons on a motor build then buy a cheap garbage turbo.
THAT SAID;
There's not enough variation in turbo tech in the world to explain why someone makes 450hp (American horsepower or otherwise) on 19psi with twins, and someone else makes 210hp on 19psi with twins. There's very obviously something missing going wrong/unexplained/dyno is configured wrong and car actually makes 380hp or something :p
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
