Which turbo's are you guys running on your sr20det's?
Im looking at the:
-GARRETT GT2871R (0,64AR) - $1350
-GARRETT GT2560R - $1050
-GARRETT GBC22-350 - $850
Im curious about the GBC22-350, anyone tried it?
I currently have a built sr20det (top (cams, springs, solid lifters etc) and bottom(rods, pistions, coated bearings, headgasket and main/head studs)) but dont wanna run any crazy numbers, only safe numbers to get the car running again.
I also dont wanna break the gearbox since i will be running the standard gearbox (5speed).
Get a GTX2860R Gen 2, it will do about 250~260kW and come all close to the side of 3000rpm on E85.
Here's a post I wrote about it: https://www.instagram.com/p/Crr_8gOyC3e/
Looks great! Sounds great aswell.
maybe the gt2871 is the way to go then.
the GTX2860R is a bit pricey
4 hours ago, Dose Pipe Sutututu said:
GT2871 is so old, it's not 2003 anymore.
True. But does it matter if its a good turbo?
gbc220-350 is a newer model, but dont know really mich about them. Tried to catch someone who runs it on a sr20
Like I said earlier, it's smaller than stock. You can just look at the numbers and compressor map to know this. Technically the turbine will flow more due to higher trim but the compressor flows less air at the same pressure ratios.
Edited by joshuaho96
Subjective, I think it's a terrible turbo when compared to today's modern offerings.
Only thing "good" about it, is that it doses very well. You get a nice suuuuuututututut lol
  • Like 2
  • Haha 1
I am now running a Aeroflow 5047 .64 rear (gtx gen2 2867 specs)
Previously ran a garret gtx gen2 2867 .82 rear
The .64 is the way to go as a lot more responsive.
I also run a stock 5 speed but its struggling and eating syncro's.
Car makes 220-270kw pending boost level.
Edited by robbo_rb180
  • Like 1
22 minutes ago, timmy94 said:
ok then Got offered
GTX2860 or GTX2867.
can get a good deal on the GTX2860R.
shall i go for that then
Gtx2867
If decide to go for more power will be ready to go for around 270-280kw and be super responsive.
1 hour ago, timmy94 said:
Whats the minimum power you think you can run on that without promblems like surge etc
Surge from what? Fuel?
The GTx2867 Will probably be alot more expensive.
If money is an issue look at other brands like mamba, pulsar, Aeroflow
  • Like 1
