Hi all,
I just purchased a '98 Stagea Autech 260RS. Based on my research, it's #412 of 1784 across both series. It has 142k km and is mostly stock, save some GT-R R34 rims and a Tomei(?) front grill. I'm based in the States, so this car was never sold here in any form. We didn't get the GT-R here until the R35, so the drivetrain is an unicorn (ironically). I'll be picking up the car in a couple weeks and driving it cross country to its new home. For now, I'm scouring the internet and educating myself on the care and feeding of these beasts. So far, I've determined that I can't just look up parts anywhere in the US, so starting to amass a list of cross-referenced parts. Anyway, I'm excited that there's an active forum for these cars and their sisters. I plan on gleaning all sorts of information from you.
Hi. I'm Kip. I've bought a car that doesn't exist where I live. I'm a fool.
-Kip
  • Like 1
https://www.sau.com.au/forums/topic/485025-fool-in-the-states/
5 hours ago, Kip said:
Hi all,
-Kip
It's not that hard. Many parts are sold direct through Nissan USA dealers now, just look up the part numbers through the parts catalog. The 260RS is entirely R33 GTR as far as drivetrain goes.
Welcome Kip.
You'll be fine. I have a car (well, "truck") that not only does not exist where I live, but I had to have  converted from LHD to RHD as well.
Both drivetrain and engine are generally R33 GTR, but you can get info here on specific differences
  • Thanks 1
On 10/26/2023 at 4:44 PM, soviet_merlin said:
:wave:
From one fool to another, I'm sure you'll be fine. Do you have any photos of the car?
Here are a couple of the "glamor shots" from the dealer. It's pretty much stock (as mentioned above), but does have a set of meister coilovers and a modified exhaust. The interior is untouched which is nice. Tires are on order to add a little more sidewall and I'll adjust the coilovers to put the wheel wells just above the tire instead of down on the rim.
  • Like 4
I didn't know Nissan USA would help me out. Very cool. That's half the battle (the first being tracking to the right part numbers).
Yeah. Reading a lot about the R33, since mine is essentially the wagon/estate/combi/avant model of it. I'm excited to have one of the ultimate sleepers.
  • 4 weeks later...
18 hours ago, soviet_merlin said:
Nice one, looks very clean! I always much prefer the boxy more aggressive look of the S1 over the S2.
Thanks. Just picked it up last week. Drove it 32 hours across the country to its new home and then some more local, holiday travel. Over 4,000 kms in all. The car can really eat up the miles.
And the petrol! It seems the car is more modified than I realized. I think it has an old school tune on it that is dumping too much fuel into the mix, based on the soot collecting on my rear bumper cover and the 13l/100km consumption I'm seeing. Regardless, it's an interesting car. I'm enjoying getting to know it. I'll get it off the ground this week and go on a fact finding mission. See if I can get a better understanding of the mods.
  • Like 1
Oh wow, that's some serious distance! That's an easy half a year worth of driving for many. I'm glad to hear it made it okay.
I wonder if the soot could also be from the exhaust setup. There's a highflow catalyst on mine that does pretty much nothing and smells terrible. I have been blaming the gunk on the bumper on that. Not sure though.
It drove beautifully. It really likes to just cruise around 130-140 kph. The exhaust quiets down. It's off boost. It just eats up the kms. It's almost zen like. 😉
You're right. The exhaust has something to do with it. I believe it's some sort of HKS exhaust, at least from the cat back. It has an ~10cm tailpipe that has both limited clearance of the bumper cover and points upwards a little. It's a cool visual that's a total 90s throwback for me, but it's creating some of the discoloration.
2 hours ago, Watermouse said:
Would a modern aftermarket ecu change that somewhat?
If you ran a wideband and tuned for a lean cruise you could save some. But it's just not an "efficient" engine design. Manufacturers have put a metric shit tone of work into reducing fuel consumption in the 35 years since that engine was born. Port design, chamber design, high compression, valve timing control, injector placement (and quality!), low tension piston rings, thin oils, smaller bearing journals, low drag engine ancillaries, etc etc. None of these modern things have you, hmmm?
It will help a little as others have said but don't expect miracles. And most tuners are not remotely interested in tuning fuel economy so expect to have to learn and do it yourself.
Welcome! You've effectively got an R33 GTR wagon, so most of those parts can come from an R33, which most Nissan spares can order for you in the US these days. Body panels will be hard, but the US has some of the best body work and trim shops if reality TV is anything to go by :D
Sounds like you might have a remapped ECU, pop the carpet out under the passenger side and see if there's any tuning shop labels on the ECU, that's usually the easiest way to tell, or you might have to open up the ECU to see if there's any EEPROMs changed out etc.
    • Hey I get it. Definitely sounds exciting, but not for me, there is almost no V10 or 12 that I really like. I don't like big engines with high cylinder count. V8s would probably be where I draw the line of "which engine would you use". Specifically an LS7 is a favorite of mine, or the 5.2 Voodoo by Ford.
    • But V12 Skyline. Like, I'm In!   Stay Tuned in the USA are jamming a V12 into a Foxbody at the moment... Just the sound of V10 or V12 is worth that adventure!
    • To put it in perspective; there is just one tuner shop that sells a single turbo kit for the RB26, at least publicly in their shop. Maybe one or two others can offer you a setup if you inquire, but I am not sure. That turbo kit is 16k in parts alone (high quality ones, but still). By the time it's installed, tuned and legalized expect it to cost 25k+. And then you still didn't take into account for any special wishes. I can't imagine legalizing an LS swap for example to be any cheaper. And if you want to legally raise power output by more than 40% of the highest-powered OEM variant of any specific car you'd have to do stress testing on a race track for 2000km. Wildly out of perspective cost and effort wise, especially for just one vehicle. But if you got too much money, I guess you could do it.
    • Yeah, I understand that TÜV is a bitch, but.... cost is not an issue when talking about putting a massive NA (or possibly large + turbo'd) V engine into a Skyline. We do it because it is fun. If mine was a project car and not a daily, I'd be finding some massive engine to put in it. Possibly one of the Toyota V12s that they make into monsters in New Zealand. Engineering is not cheap and easy here either (although definitely easier and cheaper than in Der Vaterland). But anything is possible, and 7L is better than ~2.5L, by about 200%.
