I'm sure this has been done to death but I couldn't find anything about the specific coolers I'm looking at.
Brief spec of car is HKS 2.8, Vcam, Garret G30-770 turbo. Power goal is 600-650HP.
I'm trying to decide between the HPI 100MM, Plazmaman 76MM & HKS 100MM. The HKS & Plazmaman are roughly the same price landed in the UK, the HPI is around £200 cheaper.
Has anyone used the HPI core? Is the HKS/Plazmaman worth the extra over the HPI? Will I see any advantage over the 100MM core vs the 76MM core?
At the moment I am leaning towards the HPI but only want to buy once :)
https://www.sau.com.au/forums/topic/485066-r32-gtr-intercooler-options/
yeah 650AWHP.
The Plazmaman is only 76mm though but they say rated to 850HP.
Hypertune seems to be overpriced for what it is, its double the price of the HPI cooler & doesnt seem like it will give much more of a gain. Hypertune just seems to be for bling youtuber points
7 hours ago, ianp said:
yeah 650AWHP.
Hypertune has had a lot of complaints here recently regarding customer service, I'd probably pass unless you want to deal with that.
They have had ALOT of complaints for a long time. Absolute fkn pricks, esp Peter Lewin. That flamin mongrel deserves a punch in his fkn nuts.
Edited by Predator1
  • Like 1
  • Haha 1
Hyperfail
Get a Plazmaman core, low IATs, good welds, good construction, good end tanks.
I run a 76mm one, and jam 2 bar (tapering down to 1.7bar) through it. IATs normally about 10~15 degrees more than ambient (and that's with the EMAP over shooting the MAP too).
1 hour ago, Dose Pipe Sutututu said:
Hyperfail
What he said. You cant go wrong with Plazmaman. If you can fit a 100mm, then might as well stick that in.
Oh yeah those IAT vs ambient temps are after going around a circuit multiple laps too.
Not quick squirt/pass kind of thing down a strip. IAT probably even lower if you do that.
  • Thanks 1
  • 3 weeks later...
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
    • Looked it up. It sounds so expensive lmao I'd rather not. Awwwww but I just love that sound
