20 hours ago, GTSBoy said:
You have a fault. The fault will be random. You will need to break out the wiring diagram and the multimeter, and start fault finding. It's a manual exercise.
Cheers  mate I've just checked every think with muiltmeter. grounds and ign all have what they should but the white and red wire for ign on the black pug its 3.6v is that normal I thought it might be for the light
Well, the tacho is either working and there is just no signal to it, or the gauge itself has a problem. If the latter....god knows what to do. If the former, then you need to a) prove continuity to the appropriate ECU pin and then b) possibly hook up an oscilloscope at the dash end of the wire to see if the signal is present.
The temp gauge is kinda the same just without the oscillosope, you're more looking to see if the resistance of the sensor measures the same at both ends of the wire.
And as for the alt light....that would seem to be a wiring problem. Which may or may not be common with the other problems.
Thank you so much for the help I go and try all that and see how I get on.  I thought it might all be because it's a 20det loom in a 25de body. I have tryed 2 clusters it's all the same. But I will give it a Crack im not to keen on have aftermarket rev and temp gaues
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
