Hi all, trying to get my AWD system working properly after a soup to nuts rebuild. The computer is throwing codes 8, 9 (ABS was deleted) and also code 18 which seems to be the issue. Today we tried the bleed procedure and still doesn’t work.
Here’s the description from the builder: on ignition the pump pumps oil, when the pressure reaches the desired value, the pump turns off and the oil is stored in the tank by closing the check valve, in our case it seems to me that it does not work and when the pump pumps up the pressure to the operating level , the sensor turns it off and the liquid is squeezed back through the pump into the tank, you can even hear the pump spinning in the opposite direction, the pressure decreases and the sensor turns on the pump again, and this all repeats endlessly.
The AWD system worked after I bought the car but not since the rebuild. I changed the G sensor to the Do-Luck unit, maybe that could also be the issue? It’s a pain to change so we haven’t tried it yet
Hopeful to get this worked out, I really wanted an AWD skyline. Thanks 🙏
https://www.sau.com.au/forums/topic/485106-attesa-code-18-pump-malfunctioning/
Probably worth starting with the 32 GTR workshop manual (you didn't say which car and don't have it on your profile).
https://www.hgeconsulting.com.au/gtr_32_service_manual_indexed.pdf section c3 stars page CH-57
My mistake yes it’s a 32 GTR, I’ll check it out but we did find the code 18 troubleshooting and all the referenced points have continuity, so the flow chart says the computer is faulty. Just seeing if anyone had a similar issue before shotgunning parts. Thanks
Yeah that does suck considering how hard these computers might be to find, wherever you are.
80s Electronics were mind blowing to the 80s, but not so much these days. Might be worth opening the computer and looking for any burned tracks or components or other obvious issues rather than replacing it straight up
I think it’s possible a defective part on the hydraulic pump like the pressure switch is causing the fault, I checked the troubleshooting flow chart again and it actually says hydraulic unit failure, so I guess that’s the pump, but my pump is cycling constantly so my thinking is either a valve was installed wrong or a part is not working properly
Or the do-luck G sensor is defective?
Issue inside the hydraulic unit was my thought after looking at the guide too, but I haven't really heard of that before. Potentially it is just the pressure switch has failed, original is not available but there are aftermarket equivalents like this from Frenchys https://frenchysperformancegarage.com/products/fpg-nissan-gt-r-attessa-pressure-switch-replacement
I can't see how the g sensor would cause the issue but it is easy to check, just unplug it. The hydraulic unit should pressure up regardless of what the ECU thinks is happening in the car
G sensors do not affect the pump. Entirely separate issues. Most likely your hydraulic unit has some fault. Is your nitrogen accumulator reasonably new? If it’s original you probably need to replace it along with whatever else is broken.
Yes the accumulator was changed new, I’ll try change the pressure switch and see if it clears the fault
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
