Hi Stageans,
I picked up a new-to-me RS260 last week. Having a good time getting to know the car, but have some things to learn. A couple general questions about what I'm supposed to be seeing light up on the dash and one random button question:
  1. When I turn on the headlights, there is no indicator light on the dash. I assume there should be the usual, generic headlamp image (usually green) somewhere on the dash. I have the blue, high beams, headlamp issue when the high beams are on. Assuming I have a bad bulb, but don't want to tear into the dash to chase an indicator light that doesn't exist. Does it exist?
  2. Similar question about the driving lights. The switch on the stalk has two positions for the driving lamps: fronts only and rears and fronts. When I roll the switch to the first position, I have no indicator light on my dash. When I rol the switch to the second position, the amber, driving lamp image lights up on the dash. Is that the correct function or is there potentially another dash bulb out?
  3. Rear driving lights: I assume there are two of them in the back. I only have one working. Rear driving lights are a bit of an anomoly in the States, so wanting to confirm I should have two in the back before I go disassembling things.
  4. To the right of the steering wheel and below the instrument binnacle, there is a two position toggle switch. It has the image of the rear windscreen, if I'm interpreting it correctly. Press it up, a light on the switch comes on, so I'm assuming it's "on". Press it down, the light goes off. I can't tell that it's doing anything. What the @#$! is this switch? Rear defrost?
Thanks in advnace.Sorry if these questions have previously been answered, but my search turned up nothing.
-Kip
https://www.sau.com.au/forums/topic/485108-new-owner-with-dash-light-questions/
I. can't be certain of 1 because mine (was) auto not manual cluster, but I don't have a main headlight (not high beam) dash light. The hint is that the dash backlights come on
2 and 3, these are fog lights. Position 1 on the switch gives you the front fog lights + parking lights including dash illumination. Position 2 turns on one rear red light as well as the dash light.  As a result you only get 1 reversing light and will forever have kindly people stopping you to tell you one of your reversing lights is out.
4. Is for the front not rear screen, you have the "Winter options pack". That switch turns on the front windscreen wiper de-icer (element in the windscreen, if the windscreen has never been replaced). You should also have heated mirrors, a centre diff lock switch and the fog lights from q 2/3. There is a separate rear demister switch
Almost no cars from that era have a low beam headlight indicator on the dash. As Duncan said, the fact that the dash lights come on used to be enough for us to know.
Modern cars with all their unnecessary bullshit (ie, backlit LCD instrument panels and daytime running lights)......that's when people started "needing" an indicator light to tell them they had the headlights on.
Excellent info. Thanks (Great detail, Duncan!)
  1. Sounds like everything is working properly as far as dash lights are concerned. Good to know. Yeah. I know the backlight comes on as an indicator that lights are on. I was just wondering if I was missing something. My previous cars, old ones too, have had a low beam indicator light. Maybe it's a US thing, IDK.
  2. Good to know about the fog lights, not driving lights. It's funny you mention helpful people letting you know you have a burned out reverse light. My bonus daughter's boyfriend let me know that one of my taillights was burned out. In reality, I was driving with the fog lights on, so only the one side lit up. He's "helpful" too.
  3. Winter options pack. Interesting. I'll look for the element on the windscreen. I do think I have an indicator on the side mirrors, but I shouldn't trust my memory. I'll look for those too. Where would the differential lock switch be? What do you mean "fog lights from a q 2/3"?
New question: Is there a way to adjust the brightness on the dash backlight? Feeling stupid, but I'm not finding it in the "normal" places.
-Kip
Sorry to be unclear, I meant that the fog lights from your questions 2 and 3 are also part of the winter pack. Generally, a bunch of rust is also part of that pack so please check the car out carefully including removing the door mirrors to check underneath.
Mine has the winter pack too and despite being rescued from snowy parts more than 20 years ago the door mirrors still needed repair.
There is no factory way to dim the dash lights. It is possible to fit a dimmer if it does trouble you, for a while adding one was part of compliance when cars came into Australia. You basically just add a variable resistor into the wire that supplies power to the dash backlight globes
I read about the rust in the door mirrors. From the outside, they seem solid. But yes, going to get in there and check them out at some point.
The dash light isn't too bad. Some modern ones really glare. These are reasonably subdued. At this point, not worth it to install a resistor. It was more of a question about not finding the adjuster. I thought I was going mad.
Again, thanks, Duncan. You seem to know your stuff.
When you do look inside the mirrors, be sure to remove the sponge that is jammed in there. That is the culprit.
  • Like 1
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
