One of the very few oil flush additives that I recommend is Wynns which is detergent based (like in the oil already). Stuff like Nulon and other cheap and nasties are just kerosene or other harsh solvents in a bottle which just makes the oil very thin. Also these formulations can be very aggressive on seals and can cause your engine to spring leaks (like Nulon did on my last car).
  • Replies 83
As i couldnt find the right grade of Mobil 1 to use, im trying the Castrol Formula R 10W-60. So far i have to say very happy as even the knock level seems to be 10-15 lower?!?!?! Will see how the car goes at the next track day...im sure it will be fine, but my understanding is Mobil 1 is typically regarded as having the best stability at high temps
I've said it before but I'll say it again just in case people haven't read it yet. I used Castrol Formula R for the first 4 or 5 oil changes (every 5000km). Then I swapped to Motul 8100, and suddenly the exhaust ran absolutely FILTHY. Then after about 1000km, a lifter got blocked. The Motul had done such a good job of cleaning the engine that it dislodged the large chunks of crap that had accumulated in the engine when using Formula R and whatever the previous owner had used before it.
So while I'm not going to actually say that Castrol added gunk into my engine causing a lifter to block, I *will* say that at the very minimum, it did absolutely nothing to help clean out the inside of the engine from whatever unknown oils were used previously. If you really want to use Castrol, I would recommend doing an engine flush between services to gradually reduce gunk buildup. The Castrol is doing jack-all in this regard for you even though as a supposed synthetic, it should be keeping it clean.
Since then I used Motul 8100 in my last 2 changes and the exhaust is now running much cleaner due to the insides of the engine now being much cleaner. And no hint of any blocked lifters.
I thought of using the 300V COMPETITION 15W50.
But which 8100 are you running 0W30 , 0W40 , 5W30 , 5W40? None of those grades suit my thinking for an oil that i will use in my turbo car at the track
This is the link to the oil i have always used, but cant find anywhere in Melb that sells it.:)http://www.mobil.com/USA-English/Lubes/PDS...bil1_15W-50.asp
Up, up, and..... a question :)
My R32 GT-R is about to land after about five months storage, so its going to need the usual complete fluid flush. I am thinking Motul for the engine, Redline for the g/box, and probably one or other for the diffs.
Now for the question: which Motul should I go for? 8100 or 4100 seems to be the most popular choice, although some of you have suggested 300V. Unfortunately the Motul website is not very helpful (for me, at least) in making the differences obvious. Could someone spell it out for me?
Also, is there a Motul oil which has less aggressive cleaning agents than 8100? After JimX's experience, I am tempted to go with something with less cleaning agents for the first change, and then swap to something more aggressive later to make sure nothing gets clogged. Thoughts?
Cheers guys :P
You could have a chat to Nathan, see what he thinks. But as for flushing, there are some "engine flush" products around that you can run through, either that or run the 8100 and drop it after 500-1000klm to give it a chance to cleap things up. My gtr hadn't been looked after too well in jp and the oil that came out was pretty bad :P terribble actually
Guest RedLineGTR
The only grades of 8100 I have seen around my area have been the 5-40W rating that’s what I have been using for the past 14 months, it’s the closest thing I have found to a good synthetic oil unless yo go for the 300V series of Motul oils which are a 100% “genuine” synthetics made from esters.
Some things I have noticed when using Motul oils for the past 14 months, might be useful for some people…meh
When using Shell Helix Ultra 5-40w, Branded as a 100% synthetic oil and after using this for a while I noticed quiet a bit of black fouling on the exhaust tip (new cat back) of the cannon muffler (it just got black very quickly after a couple of good fangs).
After switching to Motul 8100 5-40w and giving my exhaust I polish the whole cannon on the outside and the 5inch tip (inside) on the 3.5inch cat back exhaust (got a bit carried away when cleaning) after 3 tank fulls of petrol the tip of the exhaust hasn’t even gotten dirty, looks like new and even recently getting a new exhaust it looks like new still after 4 weeks of use and fanging. The status of tuned had not be changed eg. Richer or leaner etc.
Can someone clarify the grade of 8100 they are using?
I'd like to know too. Also, where are people purchasing the stuff? Much variance in pricing between retailers (ie. is it worth the ring around, or just rock up to local oil supplier)?
Cheers,
Lucien.
I'm using 5/40 8100. $60 at UAS $65 most other places.
JustJap have it for $65 with a filter (although I'd rather buy a seperate filter).
Also since using 8100 my exhaust has been punching out a helluva lotta black stuff - I'm assuming it's just crap in the exhaust rather than from the engine but yeah I've done about 300km on it so I'll be changing it again and getting a new cat (the old one is tiny).
Again - I don't think it's the oil related but yeah, where I warm up my car there is a bike and the exhaust is about 10cm away from it and I noticed the other day it's been splattered hard with about 3-5mm of crap.. haha I think it's cos of some rain getting into the exhaust first then getting splattered out.. but it's pretty chunk.
My experience with the GTR (no remote oil cooler)is as follows,
Castrol R 10W-60 - Has good oil pressure showing on the gauge but fuel economy and performance seem to suffer marginally. Just feels less happy to rev. Worst thing about it was that it consistantly had the engine oil temp up around 100 degrees on constant highway speeds and was quick to go higher if pushing the car.
Mobil 1 10w-30 - Lower indicated oil pressure when warm but still acceptable. Revs easier but the biggest difference is that the oil temp sits around 85 degrees on the highway and is much slower to rise when the car is pushed hard. I am very specific about using the 10w-30 and not the other Mobil 1 types.
Personally, I feel far more comfortable with a little less indicated oil pressure but cooler running and more stable oil temp.
I've used all sorts of oil in all sorts of cars and they have always come out black (even with new cars) so its never been a concern for me. Only car that I've ever seen drop clean looking oil after a service was a holden ute that ran on LPG.
I cant fault the Mobil 1 but having said that would be keen to give the Redline stuff a try at some stage and see if theres a difference.
  • 4 months later...
Time to drag this one up again...
I'm about to do a change, have been running Motul 300v 15-50 for a year or so and have been pretty happy with the performance.
Some vic guys swear by Castrol Formula R 10-60 (i think) and am considering the change - alot of vic guys run it at the track with good results (or lack of blow ups?!?) and i'm preparing for another track day in April
I however have one sump's worth of 300v left waiting to go in... so what do I do, run the 300v or swap to Castrol for the track then back to 300v for the road?
Cheers
    • Yes, it is indeed that time of year again - the time has come once again for us to sit and discuss the state of our club, and any/all future possibilities! And yes, it is the perfect opportunity to sit and have a bite to eat and/or a drink with all SAU NSW members! Every wondered whether there is more to SAU NSW than just our beloved cruises? Well this is ALSO the best opportunity to quell your curiosity! We discuss everything SAU NSW from current financial position, performance of the club over the past year, the good things we did, the bad things we did, as well as the things we could do better or different! Not to mention, we talk plenty of car talk too.. After all, we're all passionate car enthusiasts! So without any ado, please save the date, and come down and get involved!   When: Sunday 4th May 2025 Where: Toongabbie Sports & Bowling Club - 12 Station Road, Toongabbie Map: https://tinyurl.com/saunsw-agm Time: Meeting will commence at 1.00pm. As usual, lunch from 12.00pm!   Agenda Items: - President's Report - Treasurer's Report - 2025 Committee Elections - State of SAUNSW & moving forward - Future Events & 2024 Calendar - Further Motions & Agenda Items - Open discussion   To our members who are also on the forum, if you would like to discuss any particular item, or have any ideas for the future of the club, please note it in this thread for discussion at the AGM within the NSW Members section of the forum. If you don't have access to the Members section of the forum, then get in touch with us! A note to our members: We remind you that as per constitution, nominations for committee positions close 21 days before our AGM (Saturday 12th April 2025). ALSO, by 12th April, any motions must be put forward, for discussion as agenda items at our AGM. Please head over to the Member's Section of the SAU Forum to post your nominations and any items you wish to be discussed! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • We're bringing Pizzas back!! Pizza Runs, to be specific... We had a practice Pizza Run a while ago, and everyone has been screaming for a proper one... So you've asked, and now we're delivering! Since your tastebuds are tingling, feast your eyes on the event details: Date: Saturday 19th April 2025 Meet Location: Parking Lot - 1 Parkview Dr, Sydney Olympic Park Meet Time: Meet at 5.30pm for a 6.00pm departure Destination: Talotta's Pizzeria, 1-3 Bridges St, Kurnell Map: https://tinyurl.com/saunsw-talottas We'll meet at the carpark on the corner of Parkview Drive and Australia Avenue in Sydney Olympic Park. When we leave the parking lot, we'll head down Australia Ave, and turn right onto Homebush Bay Drive at the large roundabout near DFO. As soon as we turn onto Homebush Bay Drive, we will be turning left onto the M4 to drive through the new M4/M8 tunnel! Everyone loves a bit of RB action through a tunnel.... We'll exit the tunnel at the Gardener's Road exit, and turn onto Princes Highway, where we'll follow it onto Rocky Point Road and then onto Taren Point Road. Once we reach Miranda, we'll turn left onto Captain Cook Dr, where we'll continue on straight until we reach Talotta's Pizzeria for some pizza goodness!!! There is a small carpark at the destination. Limited spaces are available, but there will be plenty of street parking in front of Talotta's There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • The time has come once again, for another SAUNSW Sunday Session! You all know the drill by now, fam... This is the perfect event to catch up with the SAUNSW crew, hang out for a coffee and a bite to eat, and get in some photos and friendly banter! So without any ado, here are the details: Date: Sunday 6th April 2025 Meet Location: Penrith Krispy Kreme (at Penrith Panthers - Panthers Place, Mulgoa Rd, Penrith) Meet Time: 8:00am Map: https://tinyurl.com/saunsw-penrithkk This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Welcome to the new year, gang! We've ticked over into 2024, so as usual, we're starting the new year with a chill social out at Aqua Golf! So without any ado, here are the details: Date: Saturday 22nd March Location: Aqua Golf - Penrith Panthers Time: 4:00pm Map: http://tinyurl.com/saunsw-aquagolf All you need to do is bring yourselves down to Penrith Panthers to come and say "HI", hang out, and maybe hit a few golf balls at the drive range. Who knows where the night may take us... What we do know is that there are plenty of food options available at the Penrith Panthers complex. For those of us keen to hit a few golf balls, prices start from $7.00 a bucket. Aqua Golf is open til late, so we have plenty of time to have a few hits and laughs with each other! This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks all! Looking forward to seeing you all there!
    • Kicking off our first Sunday Session for 2025, we'll be heading to the delectable Self Raised Snack Shoppe!! Get your tastebuds ready for a mouth-watering toastie and coffee! As always, this is the best place to meet up with the SAUNSW fam for a coffee, bite to eat, and a chat! So what are you waiting for? Block out the calendar, set your alarm in the morning, and come down to hang out with the SAUNSW fam! Date: Sunday 9th March Meet Location: Self Raised Snack Shoppe - Shop 4, 8/20 Sarsfield Cct, Bexley North NSW 2207 (carpark entry via Slade Road) Meet Time: Meet at 8:00am Map: https://tinyurl.com/saunsw-selfraised This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
