weikleenget Posted November 28, 2023 Share Posted November 28, 2023 Hi, the fuel door cable where it connects to the release latch in the cabin broke in my R32, I can’t seem to find this cable for sale. Does anybody know if the R34 version can work or another solution? Thanks Link to comment https://www.sau.com.au/forums/topic/485115-fuel-door-and-trunk-release-cable/ Share on other sites More sharing options...
soviet_merlin Posted November 28, 2023 Share Posted November 28, 2023 I'm pretty sure @Duncan mentioned this in one of his build threads. Can't remember what the verdict was though. Link to comment https://www.sau.com.au/forums/topic/485115-fuel-door-and-trunk-release-cable/#findComment-7984944 Share on other sites More sharing options...
Duncan Posted November 28, 2023 Share Posted November 28, 2023 I have an R34 one in my 32, but that is because the other end at the fuel door broke (plastic in 32, steel in 34). Is the 2nd pic a temporary fix? I think it is repairable, I'm not sure of the method but it would be worth either checking around or getting an instrument repairer to look at it Link to comment https://www.sau.com.au/forums/topic/485115-fuel-door-and-trunk-release-cable/#findComment-7984945 Share on other sites More sharing options...
weikleenget Posted November 28, 2023 Author Share Posted November 28, 2023 Yeah he tried a fix but it broke again. The cable is the exact same length and connection between 32 and 34, in other words no other modification is needed? The 34 cable is available for sale Link to comment https://www.sau.com.au/forums/topic/485115-fuel-door-and-trunk-release-cable/#findComment-7984955 Share on other sites More sharing options...
kevboost7 Posted November 28, 2023 Share Posted November 28, 2023 I replaced this cable recently. I purchased it from concept Z performance. And it was a R34 one. Can confirm it works. https://conceptzperformance.com/nissan-infiniti-nissan-oem-trunk-lid-gas-filler-opener-cable-nissan-skyline-r34-gt-r-gtt-84650-aa100_p_56279.php Link to comment https://www.sau.com.au/forums/topic/485115-fuel-door-and-trunk-release-cable/#findComment-7984957 Share on other sites More sharing options...
kevboost7 Posted November 28, 2023 Share Posted November 28, 2023 Some advice, i realized that the cable broke, because there is a big ass washer on the seatbelt thing and it was squeezing the cable causing it to have extra tension. Make sure that big washer isn't sandwiching the cable. 1 Link to comment https://www.sau.com.au/forums/topic/485115-fuel-door-and-trunk-release-cable/#findComment-7984958 Share on other sites More sharing options...
Duncan Posted November 28, 2023 Share Posted November 28, 2023 2 hours ago, weikleenget said: Yeah he tried a fix but it broke again. The cable is the exact same length and connection between 32 and 34, in other words no other modification is needed? The 34 cable is available for sale The R34 cable is longer but it doesn't matter, because as long as the ends are in the right place there is just a bigger loop in the rest of the cable. I see a worldwide shortage of 34 fuel door release cables starting very soon. Australia's stock already sold out 3 months back Link to comment https://www.sau.com.au/forums/topic/485115-fuel-door-and-trunk-release-cable/#findComment-7984963 Share on other sites More sharing options...
joshuaho96 Posted November 28, 2023 Share Posted November 28, 2023 1 hour ago, Duncan said: The R34 cable is longer but it doesn't matter, because as long as the ends are in the right place there is just a bigger loop in the rest of the cable. I see a worldwide shortage of 34 fuel door release cables starting very soon. Australia's stock already sold out 3 months back I'm confused honestly by this, as far as I can tell isn't this basically all repairable using off the shelf bicycle/motorcycle components? Other than the inevitable injection molded plastic bits. The T end piece is a very common bowden cable part that just requires the right crimper to replace, etc. 1 Link to comment https://www.sau.com.au/forums/topic/485115-fuel-door-and-trunk-release-cable/#findComment-7984969 Share on other sites More sharing options...
Duncan Posted November 28, 2023 Share Posted November 28, 2023 15 minutes ago, joshuaho96 said: I'm confused honestly by this, as far as I can tell isn't this basically all repairable using off the shelf bicycle/motorcycle components? Other than the inevitable injection molded plastic bits. The T end piece is a very common bowden cable part that just requires the right crimper to replace, etc. thanks Josh, that is exactly what I was trying to get at, I just wasn't aware of the term or method. Please fix this one instead of reducing the parts remaining in a small pool! Edit: sorry, to be clear, the fuel release end in the 32 is a plastic catch in a plastic thread which cracks....I could not see a practical way of fixing that beyond 3d design and printing which is outside my skill set Link to comment https://www.sau.com.au/forums/topic/485115-fuel-door-and-trunk-release-cable/#findComment-7984970 Share on other sites More sharing options...
