i went to my machanic the other day as i've been noticing a strong fuel smell from my car, he noticed it as well and before asking me what petrol i use he says you use BP ultimate don't you, he then told me that theres been a few problems with the fuel and the seals on fuel pumps, a few people using the fuel have had this problem and have had to replace fuel pumps but it not being covered by insurance due to "contaminated fuel" just seeing if anyone has heard of this latley??
https://www.sau.com.au/forums/topic/48512-bp-ultimate-problems/
Check that the fuel cap is secure, and that there are no leaks near or around. Also jack up the car and check underneath where the tank is for any leaks, could just be a small leak that can easily be plugged up...
you wouldnt want that to catch alight from the exhaust.....big dramas....
Let us know what you find out..
I work at Bp shepparton here in VIC and our BP ultimate is far better than those that are in the city, the reason you get bad fuel is that if you live in urban areas , the simple answer is more people use fuel and with a 5000 litre fuel tank the last 1000 is basically dregs take my advice fill up in the early hours of the morning when they've just filled the tanks or fill up in stations not used as much, those out of the way bastard truck stops
Patchy, I am sure there is some truth in what you say, but I would be surprised if 20% of a tanks contents could be considered to be "dregs". If station tanks, pumps and filters are properly maintained, this should not be an issue. Clearly it is with some, though.
Cheers.
it would not be 20% of tanks if you considered that premium, unleaded and diesel all house about 35,000 litres. Bp ultimate is the smallest tank and about those filters i have been working at bp for over 12 months and have never seen any cleaning done to the tanks or the filters so unless there self cleaning... How clean is your petrol?
i have managed a servo, and let me ask you, have you ever seen any big pumping trucks flushing the tanks out to clean them, i have never heard of it being done at quix(mobil) EVER. never personally seen or heard of them being cleaned and at quix as long as the water is below 1000L it is deemed clean, reassuring huh?
Hi guys. I have a little knowledge of refineries and the chemistry involved. My understanding is that the BP Ultimate is refined as a 98 octane fuel, which means that the crude cut used as the base fuel is at or near 98 octane. Whereas the Shell Optimax is a base 95 octane fuel (or maybe 96), which then has various additives mixed in to boost the octane level. This way, Shell save on refining costs, but have more additive costs - the refining costs will be the bigger of the two!
Any gasoline fuel, if left for a long period in an atmospheric tank (which all station tanks are), will "weather" - i.e. they will gradually lose the more volatile components (it's all a matter of vapour pressure and the tank "breathing"through the vent). This will generally cause the octane of the weathered fuel to be reduced.
Hope this helps.
Cheers.
Some early R32 and R33 Skylines arn't preimum fuel cars and therefore you shouldn't be using preuim fuel anyway, if your Skyline is after 1995 then they will all be preimum only cars, where as before that it's a mix so you should look up your manual that check that out.
Some unleaded cars will have problems with preimum fuels as they will burn out filters etc quicker than normal.
Also about the fuel:
BP Utimate and mobil Vortex, are 98% ron fuel they don't have any cleaners in them.
Shell optimax is 98% ron fuel but with a cleaner in it, so it will help to clean out your fuel system.
I've run Shell optimax in my own unleaded car it ran much better but Shell state that you shouldn't use premium fuels in unleads more more than once or twice in a month as it can cause problems for the engine.
Also had a WRX and ran all 3 types of fuel through it and the Shell fuel ended being the best out of the three providing much more power and resposne.
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 馃ぃ, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
    • This is mine, works a treat for the cars, suction is good, I use the Bissell clean and protect stuff I have found giving it a good spray and light scrub with the soft brush on the head of the nossle for carpet, and a rub with a microfibre for cloth seats and cloth door trims, prior to another quick spray before vacuuming it up works the best @GTSBoy You would surprised on what it gets out of carpet and seats that actually "look" clean, I recommend that you test drive yours when you have a little time to kill, then post pics of the muddy looking water that I believe you will find
