2008 Nissan Skyline 370GT Coupe - Should the door unlock when the key fob is close & I try to open the door?
Hi,
I recently had some panel work on my drivers door. It took ages as they had to order the side mirror from Japan.
The repair guys are very good, and will look into it, but I thought I better check before I demand a fix.
I am sure that before the work, when the car was locked, it would auto unlock if I had the key close enough to the door (even in my pocked, so not that close) and try to open the locked door. Am I remembering correctly? and should the same occur for the passenger door?"
The other thing that is not quite right, is that when I pop the boot, it only pops up about a millimeter. How much should I expect the boot to pop up when I click the boot release. Looking at mine, you cant even tell the boot is unlocked. I also note that when I close the boot, it comes down harder than what I remember.
On my ADM Infiniti G37 there is a soft button on the door handle (both driver and passenger side), that when pressed with your keys in proximity locks/unlocks the car (press once to unlock just the drivers door, press it twice quickly to unlock the passenger door as well). I assume the JDM V36 Skyline is the same.
Yes, my boot does the same only opening approx. 1mm - you can barely tell it is popped open. And yes, the boot closes hard if you just push it down (like my kids constantly do).
  • Thanks 1
I haven't had the car for over two months, and that sounds kind-a familiar. I'll try it tomorrow. I'm still getting used to the car again, after driving hire cars for the last two+ months. They had it so I could just grab the door handle, and maybe thats where I was confusing it with. Although, the double press for the passenger is new to me.:91_thumbsup:
With the boot, I am sure I used to be able to see that it was popped open. But again, maybe I am used to other cars now, and relied on the dashboard light. Anyone know if it's a spring or the struts or totally normal from new, that would be the cause for its lack of sticking up?
PS: for me, the 1mm for the boot is an exaggeration. from memory, it looks like its 100% close, but when you lift it, the lock is disengaged.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
