Hi Guys, i have a freshly built rb25/30det s2 head runs mint makes a nice 410kw on e50 but my oil pressure seems very high, it has a brandnew NITTO oil pump with gtr pickup...
Oil pressure on start up is 100psi, even when both oil and coolant temp are at running temp and after a 2km drive up my hill/mountain which i live at the bottom of and about another 1km along the flat it stays at around 100psi untill probably about that 3km of gentle driving it drops down to a cruising pressure of about 60psi and plays ball and flucuates from approx. 25psi-80psi depending on revs like you'd expect.
Ive got oil cooler with filter relocation and two seperate oil pressure sensor, one going to a gauge and the other is a brandnew bosch combined oil temp/pressure sensor going to my link ecu which shows on my powertune dash and both gauge and dash are showing the same oil pressure readings.
To me the 100psi seems high? Also to add im using 15w-60 HPR15 Penrite full synthetic oil..
Cheers!!
Agreed on both counts...depending on engine builder opinion and clearances a lighter oil might lower the pressure at cold idle but presumably 100psi is your oil relief spring pressure and is not dangerously high
I run at Nitto pump too, albeit I use 15W50
~7 to 8bar cold start is completely normal, in winter I've seen 8 bar+
Also does your oil filter/cooler have a thermostat?
15 minutes ago, Driftieboy said:
Ok awesome thanks everyone! Good to have some reassurance!! No oil thermo...
Get a thermostat, helps with getting the oil at operating temp/viscosity quicker. Also reducing the likelihood of over chilling the oil when you're out and about town on a cold day.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
