So basically my car randomly starts binding asif I have my centre diff locked, It seems to get triggered the most when I’m parking (back & fourths with sharp steering) or turning sharp really slowly, or sometimes it’s just happens when I’m driving, so when this “lock” feeling is active my car shudders when accelerating asif the car is still locked in awd. I’ve had this issue ever since I have had the car tuned with a GTR 33 box, I’ve rebuilt gearbox, replace clutch packs with hood condition ones, reconditioned prop shaft, full hard race suspension. My car used to be auto also but diffs are still the same. I’m using haltech elite 2500 with the harness adapter. I used a RWD TPS, would that affect the signal to the atessa in anyway?
https://www.sau.com.au/forums/topic/485149-shudder-rear-wheels-binding/
Does it go away if you disable the transfer case?
I remember Jetwreck had a similar problem with his M35, don't remember him ever getting to the bottom of it.
What do you mean you " had the car tuned with a GTR 33 box,". You don't list a car in your profile, is it a 33 GTR or something else?
And, is this the 4wd harness adapter you are talking about https://www.haltech.com/product/ht-038001-nissan-attesa-4wd-tps-adaptor/
And, what do you mean by a RWD TPS, what is it out of?
*edit* one more question....what is the rear diff?
7 hours ago, SLIXK said:
Yes, goes away when I pull the front shaft
It would be good to test what happens if you disconnect both the failsafe and main ETS solenoid on the actuator block. If it goes away then for some reason it's commanding AWD when it shouldn't. Which could mean your tires are unevenly worn. If it still binds also de-power the pump. If that fixes it then something is wrong with your actuator block leaking pump pressure when it shouldn't. If all of that doesn't work then it has to be your transfer case preload or something like that.
I would assume S2 c34 awd with a FFP. Can’t run the S2 throttle body because they are very long and was probably an auto converted to manual.  I have a haltech plug and play harness and don’t run the attessa awd adapter. Maybe the output is configured incorrectly
Yeah I've got FFP on my manual converted s1 and the standard throttle and TPS were OK, and 4wd is working fine with the Link with no adapter (although, the shop may have done the famous "secret squirrel tweak")
I have a c34 rs4v , I have the plug play adapter harness so the 2500 elite plugs into the factory loom. Guy who tuned car mentioned that part you’ve listed when I told him about the shudder, but he ended up saying it’s built into the adapter harness.. unsure of diff but it should be factory, I’ve never changed it. Car came from Japan at 70xxx kms. TPS is out of a RWD stagea.
Is the actuator block located on the gearbox ? My gearbox is recently rebuilt, replaced clutch packs with good condition ones also.
Actuator block on the R33 is crammed opposite the exhaust under the steel trunk panel. On an R32 you can just pull the ATTESA fuses and it will deactivate the pump.
This is my stagea with r33 gearbox, I just had the box rebuilt not long ago, but we have found out this part is leaking, could that cause the symptoms I’m having?
The part you have circled is the attessa actuator to transfer case flange. It is worth fixing the leak but that is unlikely to be your problem. pCH-90 of the r32 manual says to seal it with "recommended sealing fluid 518" which I understand is loctite 518
No, a leak if anything will just bleed off transfer case pressure which should lessen the symptoms rather than worsen it. The actuator block lives somewhere above the fuel tank or rear diff. Looks like this:
  • 3 weeks later...
Factory diff as far as I know.. unless someone changed it in Japan
Edited by SLIXK
Opps already answered this question
Attessa actuator to transfer case flange fixed
That’s above the rear diff I’m sure
Can I access the actuator to disconnect it without dropping the diff, and I’ve used 2 different set of wheels and it shakes and binds with both, and how can you de-power the pump, also if none of that works could my diff be getting stuck somehow?
You probably can get to it without dropping the diff, it's just going to require some quality time. Wear good thick gloves and a long sleeved shirt that you don't mind getting ruined.
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
