Shudder & Rear wheels binding
SLIXK
 Share
So basically my car randomly starts binding asif I have my centre diff locked, It seems to get triggered the most when I’m parking (back & fourths with sharp steering) or turning sharp really slowly, or sometimes it’s just happens when I’m driving, so when this “lock” feeling is active my car shudders when accelerating asif the car is still locked in awd. I’ve had this issue ever since I have had the car tuned with a GTR 33 box, I’ve rebuilt gearbox, replace clutch packs with hood condition ones, reconditioned prop shaft, full hard race suspension. My car used to be auto also but diffs are still the same. I’m using haltech elite 2500 with the harness adapter. I used a RWD TPS, would that affect the signal to the atessa in anyway?
Does it go away if you disable the transfer case?
I remember Jetwreck had a similar problem with his M35, don't remember him ever getting to the bottom of it.
What do you mean you " had the car tuned with a GTR 33 box,". You don't list a car in your profile, is it a 33 GTR or something else?
And, is this the 4wd harness adapter you are talking about https://www.haltech.com/product/ht-038001-nissan-attesa-4wd-tps-adaptor/
And, what do you mean by a RWD TPS, what is it out of?
*edit* one more question....what is the rear diff?
7 hours ago, SLIXK said:
Yes, goes away when I pull the front shaft
It would be good to test what happens if you disconnect both the failsafe and main ETS solenoid on the actuator block. If it goes away then for some reason it's commanding AWD when it shouldn't. Which could mean your tires are unevenly worn. If it still binds also de-power the pump. If that fixes it then something is wrong with your actuator block leaking pump pressure when it shouldn't. If all of that doesn't work then it has to be your transfer case preload or something like that.
I would assume S2 c34 awd with a FFP. Can’t run the S2 throttle body because they are very long and was probably an auto converted to manual.  I have a haltech plug and play harness and don’t run the attessa awd adapter. Maybe the output is configured incorrectly
I have a c34 rs4v , I have the plug play adapter harness so the 2500 elite plugs into the factory loom. Guy who tuned car mentioned that part you’ve listed when I told him about the shudder, but he ended up saying it’s built into the adapter harness.. unsure of diff but it should be factory, I’ve never changed it. Car came from Japan at 70xxx kms. TPS is out of a RWD stagea.
Is the actuator block located on the gearbox ? My gearbox is recently rebuilt, replaced clutch packs with good condition ones also.
Actuator block on the R33 is crammed opposite the exhaust under the steel trunk panel. On an R32 you can just pull the ATTESA fuses and it will deactivate the pump.
This is my stagea with r33 gearbox, I just had the box rebuilt not long ago, but we have found out this part is leaking, could that cause the symptoms I’m having?
The part you have circled is the attessa actuator to transfer case flange. It is worth fixing the leak but that is unlikely to be your problem. pCH-90 of the r32 manual says to seal it with "recommended sealing fluid 518" which I understand is loctite 518
No, a leak if anything will just bleed off transfer case pressure which should lessen the symptoms rather than worsen it. The actuator block lives somewhere above the fuel tank or rear diff. Looks like this:
  • 3 weeks later...
Factory diff as far as I know.. unless someone changed it in Japan
Edited by SLIXK
Opps already answered this question
Attessa actuator to transfer case flange fixed
That’s above the rear diff I’m sure
Can I access the actuator to disconnect it without dropping the diff, and I’ve used 2 different set of wheels and it shakes and binds with both, and how can you de-power the pump, also if none of that works could my diff be getting stuck somehow?
You probably can get to it without dropping the diff, it's just going to require some quality time. Wear good thick gloves and a long sleeved shirt that you don't mind getting ruined.
 Share
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
