Hey,
I was wondering if anyone could help with a photo or diagram or advice on how to wire the 8 pin hazard switch into an R34 GTT?
We're currently replacing the R33 hazard switch that was in the car when we brought her last month. However, we are having trouble working out what the pin config is on the R34 switch (i.e. what pin connects to where) and how this correlates to the current R33 connections?
Thanks in advance for any help 🙂
https://www.sau.com.au/forums/topic/485153-r34-hazard-switch-wiring-help/
Awesome thank you for providing us with the R33 diagrams they are a lot clearer than the drawings we were working too! 🙂
The biggest difference we're finding is the R33 connector we've just removed has 2 rows of 4 pins but our R34 connector has 1 row of 5 pins and 1 row of 3 pins (1 on the left, a gap in the middle and then 2 on the right) 🥺
Yuh, she's pretty simple when you study it for a few minutes.
When the hazard switch is off, the power to the indicators is fed from one fuse, across the first 2 terminals to make power available to the flasher unit, and that then gets sent to either the left or the right lights according to the flasher switch position.
When the hazard switch is on, the power from the indicator feed is replaced by the dedicated feed from the next terminal down, gets sent out to the flasher unit, then comes back into the hazard switch where it gets forwarded on to both the left and right lights. You can tell what terminal is what by checking for what contacts change between switching on and off. The three that are common when on are the light feeders. The three that swap inlets with a common outlet are the power supplies. The other terminals are for the local (night) light, one of which is earth and the other is fed from the parker position on the headlight switch. These could be reversed without problem, assuming it's a globe and not an LED.
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
