Hey, everyone,
I had an unfortunate thing happen to me while changing out cams. One of the cam cap bolts snapped in the second-to-last cap of the exhaust cam. I really don’t want to spend a whole day taking everything apart and putting it back together for the fifth time. Is it possible to just removing the one cam cap and extract the broken bolt without taking everything else apart (everything involved with loosening belt tension and removing the other cam caps)? I just want to know if it’s possible to do without breaking my cam. Would it lessen the risk if I rotate the cam to where the lobes in that area are not being pushed on by the valves springs?
https://www.sau.com.au/forums/topic/485159-rb26-cam-cap-bolt-snapped/
Yeah that is fine, you can change one cap at a time.
If it was my engine however I would treat every bolt as suspects (why would just one break?) and replace every bolt either with new nissan parts or switch to cam studs
That’s good to know.
It was human error. I over torqued the bolt. I barely felt the click in my 3/8 torque wrench and kept turning the bolt.
I have broken old cam cap bolts a couple of times. In my experience, they don't age well, and better to plan to replace with new bolts if yours are 5+ years old. Drilling out the broken bolt section was a bit messy with the engine in the car, but, turned out fine. I now use the Tomei cam bolt studs although, even broke one of those and it was only a few years old. DEFINITELY something to be very gentle with.
Yeah. The more I think about it, the more I want to go with replacing all of them. The only thing keep me from doing that is that some bolt seem to be seized in the cam caps. I have no idea how to pull those things out without possibly damaging the caps.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
