So I finally bolted this puppy on my recent trip back home:
https://www.alphaomegaracing.com/product/monstar-tailshaft/
I noticed on a long drive through traffic, I started getting some vibration on the motorway around 140+ (after traffic). I'm guessing it expands ever so slightly once heated up closing up clearances.
We swapped back to the oem drive shaft and no vibration.
Anyone else running similar drive shaft? Is there any way to get rid of the vibration? I'm already running whiteline subframe bushes and Nismo rear diff bushes.
Def seemed to be more rev happy and responsive with the 1 piece though!
https://www.sau.com.au/forums/topic/485160-one-piece-drive-shaft/
3 hours ago, Predator1 said:
Any ideas how much power difference it makes?
Highly doubt it, and you're making like 10x the power of your average Toyota 86 or Honda shit box, so light weight or not, you're not really going to notice.
  • Haha 1
Have a Google IRT max tail shaft speed
What is your tail shaft speed?
Calculations are based off tail shaft speed (RPM), length, material type, material thickness and diameter
Balancing should be done at a higher rpm than your average steet car if your turning high rpm
Phasing needs to be correct
And uni angle should be in spec, no uni angle is bad, to much angle is bad, uni joints apparently like a little angle to help their internal bearings spin, some say rule of thumb is between 0.5° and 1.5° for high rpm
This is why jacked up really high 4x4's do uni's
I had issues with my 2 piece when I lowered my K-frame by only 10mm, it basically kept chewing out the couplers because the alignment was out of spec
Like you it developed high speed vibration, started about 90 mph, and was like a earth quake at 124 mph
I got my alignment right, rebuilt/rebalanced the tail shaft, and now it's good to go
2 piece tail shafts have alot of advantages over a 1 piece when you look deep, especially on a street car
Thanks for posting your experience, I was looking at getting one of these. Though, still not sure if the money would be better spent just getting the OEM shaft overhauled.
Thank you, I've literally copied that and will ask my workshop.
I dont know my tailshaft speed, I would assume the speed would match the oem shaft, as it would depend on my gear ratios?
Was that an expensive exercise having it rebuilt? How long did it take?
In terms of max tailshaft RPM. I'm not sure either. I bought it as I saw the Xtreme GTR was running it. I believe he also runs an Albins with the same ratios, and he revs it to 10k IIRC.
I definitely felt the engine to be more free revving with the alpha omega tail shaft. The vibrations were def the shaft, because last week, we swapped it back to my oem shaft, and the vibrations are gone... and I noticed the engine wasnt as rev happy as before(I'm super sensitive).
One thing I just realised was that when I used LC to launch with the OEM shaft, it bogged down very bad. The last launch I did with the 1 piece shaft, it didnt bog at all. I'll upload some videos soon. The launch strategy was IDENTICAL.. I tried to pre-load the drivetrain, then let it out.
I booked it so it was less than a 1 day affair to drop it off, for them to pull it apart, rebuild and balance it, it was only a hour or so later when they rang to say it was ready for pickup
I think it was around $800????, that also included the new, Hardy Spicer uni's, couplers and centre bearing
Did you get the exact same as the Xtreme GTR, as in material, wall thickness and diameter
What was done, if anything, to the Xtreme GTR IRT the uni angles?
Thats a bit pricey haha, but let me see. I'll try to find someone local here if they can check and balance it.
Re Xtreme - I have no idea. I just know they were running one from their website and facebook.
I'll swap the tailshaft out tomorrow and see how it goes.
1 hour ago, GTSBoy said:
I spent >$1K at Spicers getting my 2-piece rebuilt with replaceable unis. It's just the cost of doing Skyline business these days.
Hardy Spicer, Eagle Farm charged me $597 for two piece rebuild as above including pickup and delivery from my workshop ya got ripped.
When you take into consideration the 2 couplers, and the centre bearing, which I priced up the OEM spec Hardey Spicer units at Repco for around $500(ish) for the 3 items, and whatever the uni cost, I didn't think the price was overboard for them to supply, strip, rebuild with new parts, balance and paint
Have you verified your driveshaft uni angle? With my single piece driveshaft on an R32, angle between trans and diff was far from ideal. I had to drop the engine a bit (Slotted out engine mounts) to get proper angle of -2/+2 between the two.
Edited by TurboTapin
  • Like 1
10 hours ago, ChrisW434 said:
I have an AlphaOmega 1piece tailshaft in my 34 GTT, no issues here. Granted, i havent spent much time going 140+ though yet. Still, love it
Good to hear - Have you noticed any vibrations at all when the shaft is hot? i mean after sitting through like 40-50 mins of traffic?
Nope. We had to space the box down by couple of mm too. But issue only seems to happen when the shaft gets hot. I mean its not an issue, but just vibrations. Def can live with, I'm just a picky cnut.
Edited by Predator1
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
