Blakeo Posted December 31, 2024 Share Posted December 31, 2024 Between a exedy hypertwin and the uniclutch, uniclutch is nicer. Clutch pedal is definitely lighter, I've only put 3000km on the car but I'm happy with it atm. 1 Link to comment https://www.sau.com.au/forums/topic/485172-uniclutch/page/2/#findComment-7996192 Share on other sites More sharing options...
Butters Posted December 31, 2024 Author Share Posted December 31, 2024 1 hour ago, Blakeo said: Between a exedy hypertwin and the uniclutch, uniclutch is nicer. Clutch pedal is definitely lighter, I've only put 3000km on the car but I'm happy with it atm. what car ? what power ? pics ? more details PLEASE Link to comment https://www.sau.com.au/forums/topic/485172-uniclutch/page/2/#findComment-7996197 Share on other sites More sharing options...
Dose Pipe Sutututu Posted December 31, 2024 Share Posted December 31, 2024 1 hour ago, Blakeo said: Between a exedy hypertwin and the uniclutch, uniclutch is nicer. Clutch pedal is definitely lighter, I've only put 3000km on the car but I'm happy with it atm. Have you given it any abuse? I.e. on the track (as in circuit not the silly roll race "track"), big RPM, big down shifts, etc. or any skid pans/drift days? That's the testing I would like to hear about. Link to comment https://www.sau.com.au/forums/topic/485172-uniclutch/page/2/#findComment-7996198 Share on other sites More sharing options...
Blakeo Posted December 31, 2024 Share Posted December 31, 2024 1 hour ago, Dose Pipe Sutututu said: Have you given it any abuse? I.e. on the track (as in circuit not the silly roll race "track"), big RPM, big down shifts, etc. or any skid pans/drift days? That's the testing I would like to hear about. Not yet, it got tuned with this clutch and made 480rwhp. I've got it off the road atm to sort out the fuel lines and hopefully make a touch over 600rwhp. I'll be taking it to the drags and drifting once I get it sorted. 3 Link to comment https://www.sau.com.au/forums/topic/485172-uniclutch/page/2/#findComment-7996203 Share on other sites More sharing options...
Dose Pipe Sutututu Posted December 31, 2024 Share Posted December 31, 2024 18 minutes ago, Blakeo said: will be taking it to the drags and drifting once I get it sorted. Will be keen to know how it holds up Link to comment https://www.sau.com.au/forums/topic/485172-uniclutch/page/2/#findComment-7996205 Share on other sites More sharing options...
RB2533 Posted January 4 Share Posted January 4 Ist post I joined after seeing this thread I have just installed on a r33gtst at first I liked it but I am finding the peddle free play changes …. To a point I have had a zero free play condition and the thrust bearing stayed engaged. I had to back off the adjustment on peddle. I am about to change slave and fit a braided line to see if I can get a better result 1 Link to comment https://www.sau.com.au/forums/topic/485172-uniclutch/page/2/#findComment-7996341 Share on other sites More sharing options...
GTSBoy Posted January 4 Share Posted January 4 7 minutes ago, RB2533 said: I am about to change slave and fit a braided line to see if I can get a better result I wouldn't be surprised if this helps. And I wouldn't be surprised if it keeps changing for a bit after the new slave&hose go on, because I find that my clutch always does this sort of shenanigans after any serious dismantlery. And then it settles down after a few corrective tweaks such as you've already done. Link to comment https://www.sau.com.au/forums/topic/485172-uniclutch/page/2/#findComment-7996342 Share on other sites More sharing options...
RB2533 Posted January 4 Share Posted January 4 5 minutes ago, GTSBoy said: I wouldn't be surprised if this helps. And I wouldn't be surprised if it keeps changing for a bit after the new slave&hose go on, because I find that my clutch always does this sort of shenanigans after any serious dismantlery. And then it settles down after a few corrective tweaks such as you've already done. I hope so. It seems pretty nice. OEM feel the lot. Link to comment https://www.sau.com.au/forums/topic/485172-uniclutch/page/2/#findComment-7996343 Share on other sites More sharing options...
Butters Posted January 4 Author Share Posted January 4 1 hour ago, RB2533 said: Ist post I joined after seeing this thread I have just installed on a r33gtst at first I liked it but I am finding the peddle free play changes …. To a point I have had a zero free play condition and the thrust bearing stayed engaged. I had to back off the adjustment on peddle. I am about to change slave and fit a braided line to see if I can get a better result Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage. So your story of tricky pedal setup seems common. Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line. Link to comment https://www.sau.com.au/forums/topic/485172-uniclutch/page/2/#findComment-7996346 Share on other sites More sharing options...
Butters Posted January 4 Author Share Posted January 4 Oh and how is the rattle when foot is on the clutch ? Link to comment https://www.sau.com.au/forums/topic/485172-uniclutch/page/2/#findComment-7996347 Share on other sites More sharing options...
RB2533 Posted January 4 Share Posted January 4 34 minutes ago, Butters said: Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage. So your story of tricky pedal setup seems common. Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line. Sport. I didn’t rebleed it cause I just removed the slave and left connected. I will change line and slave and see how it goes. Link to comment https://www.sau.com.au/forums/topic/485172-uniclutch/page/2/#findComment-7996348 Share on other sites More sharing options...
RB2533 Posted January 9 Share Posted January 9 Ok so I have sorted everything with my uniclutch and i can offer up a bit of feedback and some things that might help others. I found problems with factory damper line. Weird shit and had trouble with peddle adjustment I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is. last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline. reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit. it feels light as and holds awesome without any noise 3 Link to comment https://www.sau.com.au/forums/topic/485172-uniclutch/page/2/#findComment-7996569 Share on other sites More sharing options...
Butters Posted January 9 Author Share Posted January 9 Thanks for taking the time to post that ! If anything changes or happens please do update us. Link to comment https://www.sau.com.au/forums/topic/485172-uniclutch/page/2/#findComment-7996571 Share on other sites More sharing options...
