Hi all,
1997 R33 GTST with ABS
Have a question regarding brake bleeding as this is the first time ive attempted it. Changed over my rotors, pads and to braided lines all in one hit and am at the stage of bleeding the brakes and have noticed that there is now a hiss sound coming from the brake pedal/engine bay area (as well as not firm) after the first bleeding process (1L of fluid added give or take, some may have recirculated into the bottle). Certinatly got air in the lines during the changeover process.
Seems like there are no bubbles coming from the bleeding nipples but definatly have a spongey feel to the pedal and definatly isnt drivable. When bleeding, it builds up plenty of pressure and as the nipple is release, with my foot down on the brake pedal, it continues a slight bit more before re pumping
In terms of the ABS system, is there something that should have been done prior to bleeding, like disconnecting it ? Is the hiss noise, that isnt something I noticed prior a damaged part or is that the air moving through the lines somewhere near the ABS ? Is this just a case of needing to do more bleeding ?
Brakes were working fine prior to this (other than being worn) and have checked everything ive touched in regards to being tight. Rolled the car back and fourth and the pads do grab (but with the foot all the way down on the brake)
Thanks
Edited by Lmic
  • Lmic changed the title to Brake bleeding After Rotor, Pad & Braided Lines Upgrade
OK, so the number one danger of inexperienced bleeding is pushing the pedal all the way down, which (depending on the state of the master cylinder bore) can push the MC piston down into an area of the bore that it never normally goes, where crud is built up, which can tear up the piston seals, leading to a recirculating/failed MC. So, put a piece of wood on the floor under the pedal to stop it at about the max travel it normally sees.
Then the next peril, which can come from the same over-actuation, is damage to the booster. I wouldn't normally worry about it, but your report of a hissing noise suggests that you might have wrecked a seal in there too.
Just consider that an air leak at the booster (I've never had one, but that sure sounds like an air leak) will not affect the hydraulic system for the brakes, the booster just helps move the rod in the master cylinder.
I would start by simply bleeding more fluid through first. In about 20 years' of stuffing with these cars with multiple caliper/master replacements etc I've only once had an issue with air in the ABS, generally as you bleed it the new fluid and any air moves through the open ABS channels and nothing gets trapped in the closed chambers; it is is only when the ABS is activated that the various cylinders move around so if the car has been stationary it is unlikely to be that. On the 32 there are 2 bleed nipples on the ABS that you can try.
There are also a couple of more modern options for bleeding the system if you are having trouble, vacuum bleeding (which I think needs a compressor) to pull fluid out of the bleed nipple, or pressure bleeding where you seal the master under pressure and just open the bleeders to let fluid through. Maybe something is on sale if you want to try them.
I'd pull the master/booster off.
That definitely sounds like something being pumped around. The check I'd be doing is looking for brake fluid between the booster and master.
When you pump it heaps with the spongey pedal still, and all bleed nipples shut, does the fluid level drop down slowly in the reservoir?
How high up is the fluid level in the reservoir? I have heard the same sound bleeding brakes before when still having air up high in the lines.
If you have let the fluid level drop too low on first bleed, you may have air in the lines closer to the master cylinder.
Which order did you bleed the rotors in?
  • Like 1
Sorry for the delayed response guys but we managed to get it sorted!
Turns out there was so much air in the lines it just took hours of bleeding to remove as much air as possible. Not sure if some air was stuck at the high point of the lines where the ABS system was or not
Ended up using a friend’s suction type bleeder at the nipple end. We kept the nipple closed, he pumped up the handheld suction bleeder while I pumped the pedal and we did quick releases of the nipple which managed to get the air out. Did this a few times on all 4 starting from the rear passenger’s side and got it working
Definitely took some time but got there in the end and now the feeling is super firm
Brakes have been bedded in and grab super well once warmed up. Lots of brake dust from the fronts, as expected, after a hills run
DBA T3 Rotors / Endless MX72 Plus Pads / GKTech Braided lines (Hard line delete) for anyone wondering
I highly recommend the Motive pressure bleeder. For R33/R34 I have confirmed the Motive 1107/1117 cap is a direct fit. Putting 20 psi at the master cylinder helps to make sure even if your bleeder threads are not airtight you will push fluid through. The vacuum bleeder setups don't work IMO. Preventing vacuum leaks on the geometry of the bleeder just isn't possible and it never seems to fully purge the system of air.
The only method I haven't tried is using a syringe of brake fluid to force fluid back in from the bleeders which might help in some cases, supposedly it helps a lot with bleeding clutches.
I also briefly used mine the other day and I ranted and raved. One of the first things anyone should have for any car.
However the cap I ordered is the 0117:
Though the adapter clearly has different names associated with it. But the options above (which I think is the same that josh above used) 100% is good for my BM57 BMC Reservoir.
Does Motive have a cap for R32's? I ask as my motive bleeder has been in a cabinet collecting dust for the last 5-6 years as I couldn't find one back then.
I think he's referring to the cap for the reservoir itself.
Motive are pretty decent, but if the cap size is the same across all Nissans then the answer would be yes. If it's different, measure and Motive will likely say "Ah yes our XYZ cap is blah diameter"
Yeah sorry i wasn't clear, so was I.
Eg in this kit, the reservoir cap is attached to the pressure bleeder via a standard nitto air fitting, therefore the cap is interchangeable with any other brand pressure bleeder that also uses a nitto fitting (Or, without too much creativity, the fitting could be swapped for another style of air fitting)
You have to email them, they really should but I've never been able to figure it out as they don't show the full list of adapter caps available anymore. CTA also has the Nitto fitting which can be adapted to Motive bleeders but requires the Nitto to BSP adapter, then a BSP to NPT adapter which is pretty hard to come by.
    • it takes so long to get things done but ... they are nearly there and we hitting the track soon again  So - at Perth Festival of Speed the car unfortunately had a decent off, wasnt me driving, wasnt the person drivings fault. Long story short car got sent very fast towards the wall without the control on throttle from the driver input and a disaster was averted but there was damage that needed to be fixed - carbon busted and alot of bent bits The splitter got munched and had to go back to get fixed - took a bit to get it there, fixed and back but got a surprise package when a new double element higher DF splitter came back - nice surprise !  and first person to have one     At a car show I took the car too some punks stole one of my carbon indicator blanks and stomped on the other so had to get a new set of headlight / indicator combo from tops stage so got front fender vents as well to put in the order     While all this was happening the new MCA golds turned up and did some fiddling around with those   Put in the flappy paddle system and clutch lockout wiring/ system   We have also put shorter gearing in top top it out at 300 kmph in 6th gear  where previously I held 5th to 282 at SMP and 277 in Perth   Looking for better control and faster acceleration     I wasnt intending on doing pedal box I was managing with the brake master replacement system I had going on and adjusted std pedals but on applying the clutch switch to the old system we found the *insert technical word here * bar that goes from the pedal to the master was bent about 40 deg and about to snap = lucky find otherwise be a bad bad time - discussion was had about getting a custom bar built to withstand the load but in reality it was time      making any suspension, wheel or anything adjustments to date has been a nightmare - aero off, adjust, check and repeat - time consuming and hard - short of going full airjack system we fashioned some external manual car lifts this will make life a million times easier     All the bent framing, some intercooler pipes and other has been fixed and replaced and after 6 months I finally have the car back at home in my control so its get to work on it, set ride heights, wheel align and will start track testing again soon   So ultimately other than a few flashy bits nothing actually looks likes its been done but in reality alot has. Typical   We'll see how all this goes
    • I'm far from an expert, but for sticking bits of metal together occasionally I got a MIG, the biggest one I could get with a 10a plug (because while I have some 15a GPOs around, they are not everywhere).  Also, because I get through SFA, I just buy the small disposable gas bottles at Bunnings, I'm not opening a BOC account to get through 1/10th of a full size bottle each year
    • FWD is different though.
    • Ignore the BOV / recirc valve question. You have an NA and shouldn't have one. If there magically is one though... It should be removed, though it shouldn't really effect it in the way one will for a turbo motor with it venting to atmosphere while running an afm.
