Hello !
I'm building an engine for my Skyline R33.
I want to use the RB26 shaft in the RB26 block.
Configuration:
RB25 S2 engine block
RB25DET NEO cylinder head
Mahle Motorsports RB25DET S2 87.00mm forged pistons
Forged H-Beam connecting rod 119.5mm
Crankshaft RB26DETT
Will this configuration be ok? I'm still thinking about converting the pistons from S2 to NEO pistons using a milling machine. I'm worried about the compression ratio. I already have all the parts except the connecting rods.
https://www.sau.com.au/forums/topic/485183-rb25det-crankshaft-from-rb26/
You’ll need a 26 piston due to the pin being in a slightly higher position to compensate for the increased stroke, you can then machine the crown to take the compression to where you want it to be
3 hours ago, Dawid20 said:
I want to use pistons from RB25 but use forged 119.5mm connecting rods and additionally adapt the pistons to the NEO head.
Your pistons will be 1mm below block deck which means less ideal squish/quench so may be easier to knocking.
Stock 25det : 121.5mm rod length + 31.5mm piston height + 35.85mm half stroke = 188.85mm.
Your combo 119.5mm rod length + 31.5mm piston height + 36.85mm half stroke = 187.85mm.
Sell your pistons and buy rb26 pistons, mill down its dome to get proper CR for rb25det neo head, that way you have proper piston to deck clearance/squish and uses common rb25/26 121.5mm rods which also have better rod/stroke ratio than less available shorter 119.5mm rods.
If have to use rb25 piston with 121.5mm rod, pistons will be 1mm above block deck :
121.5mm rod length + 31.5mm piston height + 36.85mm half stroke = 189.85mm
Can use thicker head gaskets to compensate pistons above block deck, cometic has rb25det 87mm head gasket thickness of 1.8mm, 1.9mm, 2mm, 2.5mm, that will work fine with pistons 1mm above block deck :
https://www.cometic.com/applications/automotive/nissan/rb-series/rb25det--152ci25l-i6
  • Like 3
19 minutes ago, silviaz said:
I heard rb25 neo engines use a rb26 crank, is this true? I can't find any info on it and the part numbers are different. Makes me wonder for the neo engine since there are less parts, what do you do if the crank is completely stuffed.
They use rb26 rods, not an rb26 crank. The throw of the crank determines the capacity of the engine (rb25 vs rb26) as the bore diameter is the same
  • Like 1
Here's some previous threads from this very site.
This one didn't resolve very clearly.
This one shows the compression situation
One where I piped up with the usual comment, and @r32-25t with his ditto, and some other useful tidbits.
If it were me doing it (and I might, if I ever have to build my 25, because I have access to a 26 crank if I want it, despite me previously saying that it's hardly worth the effort), I'd just call up Nitto and say, "Hey, here's my plan, what piston can you magic up for me?", and leave it to them to make a nice forgey with the required combo of pin height and crown volume. They probably use the same blanks for all their RB pistons anyway, and just carve out what needs to be carved out as required.
  • Like 1
    • Hey everyone, just wanted to let you know about an app I use to track the modifications, repairs, servicing etc I do to my R33 GTR. You might like to use it as well. I'm biased because my son just wrote and released it! But I think you might find it useful to... https://trackmymods.com
    • Hey everyone, been on here for a while, but never introduced myself before. 1st import was a R32 GTS Type M, then R33 GTS, now R33 GTR - each one sold to help pay for the next one. Over the years my son has seen me modify and do changes to my imports and was one of the reasons for him to build an app for car enthusiasts like us. (He can only afford a 2007 Honda at the moment, but he'll get there!) Anyway, bit of a proud Dad moment as he's released an app that I use and you all might like to as well. https://trackmymods.com
    • It will sound tragic and you wished you didn't have 1x exhaust per turbo. There's a reason why most S55 owners change to a single mid pipe.
    • Echo the comments about the well preserved condition it's in. It has the aero bumper too for extra points. Nice car, and please keep it like that! 🙂
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
