Hi Guys
I've got a brand new 25det neo gearbox and just installed the brand new shifter, put the snap ring in and with how tight the shifter and snap ring are if you wriggle the shifter it will come out. My question is are all snap rings the same or does the 25 neo gearbox have a wider snap ring or is it possible for the bush on the bottom of the shifter to be the wrong one. Shifter was brought separately. Any advice would be greatly appreciated.
Cheers
Edited by couchboy
https://www.sau.com.au/forums/topic/485200-shifter-slips-past-snap-ring/
There definitely are 2 bush sizes, I've been caught out by that too....but that won't affect whether the shifter is retained, it would either not fit (large bush in small hole) or be super loose (opposite).
However, I've never understood why, but there are 2 snap rings on the shifter....
Update: took the cup out to check for size and is correct size. I think it just needed more lube as it is seated correctly now and can put the second snap ring in under the one that goes in the groove 🥳. cheer guys 🤙
  • Like 1
Me again 🤣, curclip, is there one size fits all or does the 25det neo box have a curtain curclip, bonus point for a part number. I do have one but it does shrink enough to be able to fit in the hole, think came out of a rb20.
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
