Hii all,
I am doing a rb25de neo engine and transmission swap on my r34 but wanna keep the rb20de harness so i spliced and joint the transmission cables(speed sensor, park neutral switch and solenoids) where needed cause the rb20 wiring is ecm.tcm
i already found an rb25 ecu with ecm tcm in one instead of separate cause my rb20 setup was ecm tcm. The rb25 transmission has an turbine sensor , does the turbine sensor need to be connected or can i just leave it disconnected?
Are there any issues that i will run into with you the setup?
This may not be the right place to say it, but the RB25NEO N/A is actually ecm with seperate TCM as well.
Those inputs are incorporated cleanly into the R34 GTT from memory (according to my memory of the workshop manual). In short, if you have the correct RB25NEO ecu, it won't have any provisions for transmissions. If you have the RB25NEO DET ECU, it should have them all.
... if it's an auto ECU.
The ecu i was going to connect to the setup is a 23740-0V010 ecu of a stagea that has ecm and tcm in one
Right, so that is the same (or very similar, I'm not sure how similar) to the GTT ECU.
I only looked at this for 15 minutes about a decade ago, but from what I remember, all of the sensors/wires/pins for the R34 N/A TCM existed on the R34 GTT main ECU. Basically the only difference between the GTT auto and GTT manual ECU was the addition of those pins, which perfectly mapped to the TCU's pins in the NA car.
This was followed by a lot of me screaming why a workshop could not have figured this out in the 3 years they had previously had the car. It's possible there's some other complication..
In my example I had a standalone transmission ECU, which I wired into following the diagrams and everything worked fine. I found other posts that people had wired the NA Autobox into the GTT ECU without issue, and after looking at the diagrams I understood why there was no obvious writeup for it. I ASSUME.
I guess i should just give it a try and see what complications i het allong the way?
I know you're in Surname, so parts availability could be pretty fkin weird. If it were me I would be trying to get the correct engine ECU/TCM (integrated or otherwise) for the engine itself. There's not always a lot of wriggle room for when it doesn't work, as it'll just flat out not work.
That said what you have is pretty close, a RB25NEO with a Stagea ECU (... gtt?) but there's still some pretty big differences between the turbo stag motor and the RB25NEO Non turbo.
So it'll either be great or really damn annoying depending on how well you study diagrams and how well Nissan lego decides to fit together in the real world.
So a small update,
i continued with using the RB20 wiring on the RB25 trans and engine and the car runs good but i have to drive the car under 3000rpm otherwise its being rev limited and doesn't want to shift to another gear, i removed the ABS fuse and shifting went smoothly only thing is the KM and ABS doesn't work but i wasn't being limited till 3000rpm.
So are their possibilities that the speed sensor 2 is creating issues?
and does anyone know where its located cause the RB25 trans has nothing on the tail like the C35 Laurel.
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
